Siemens c55 sms control help please
Results 1 to 40 of 86
Threaded View
  1. #32
     @ Device HS_OSC         ' High Speed Crystal
    define OSC 20     ' Check the spelling of OSC, must be in capital letter
    Include "modedefs.bas" ' Include serial modes
    Define	LCD_DREG	PORTB           'Lcd D 4-bit parallel register starts at PortB.4 to PortB.7
    Define	LCD_DBIT	4
    Define	LCD_RSREG	PORTB
    Define	LCD_RSBIT	2
    Define	LCD_EREG	PORTB
    Define	LCD_EBIT	3
    Define  LCD_COMMANDUS   2000	      ' Command Delay (uS)
    Define  LCD_DATAUS      50 	     ' Data Delay (uS)
    DEFINE  OSC         20                'Define oscilator frequency
    DEFINE LCD_LINES 4 'Number lines on LCD
    DEFINE HSER_SPBRG 129 ' 9600 Baud @ 20MHz, 0.16%
    myarray var byte[4]
    TrisD.2=0
    TrisC.6=0
    TrisC.7=1
    B0 var byte
    High portD.2
    Pause 500
    Low portD.2
    Pause 500
    High portD.2
    Pause 500
    Low portD.2
    Pause 500
    LOOP:
    HSEROUT["AT+CPMS=",34,"SM",34,13]
    HSERIN 5000,LOOP,[WAIT("OK")]
    ' have add   success:High PortD.2   and works
    IP:
    HSEROUT["AT+CMGR=1",13,10]
    HSERIN 5000,IP,[WAIT("OK")]
    IT:
    HSERIN 5000,IT,[WAIT("OK")] ' from here stops and dont go to IT: , have puted HSERIN 5000,IT,[WAIT(13,10), STR myarray\4] tha same resolt and have puted HSERIN 5000,IT,[WAIT(13,10)] works led ligth and final have puted HSERIN 5000,IT,[WAIT("OK")] wait for the last OK afther pdu array and do not work and do not goto IT
    success:
    High PortD.2
    Hterminal gives this:
    AT+CPMS="SM"
    +CPMS: 1,15,1,15,1,15
    OK
    AT+CMGR=1
    +CMGR: 1,,23
    0791539126010000240C915391663921010000807070819341 400453FA1B0E
    OK
    Yes, yes, and, yes, so...
    And how much of your 'program' are you leaving out? I get the feeling that you're not showing everything and that something else is screwing up this whole operation.
  1. sms to control pic..pls help...
    By Ziki in forum mel PIC BASIC Pro
    Last Post: - 12th April 2010, 21:19
  2. Replies: 11
    Last Post: - 19th August 2009, 15:23
  3. SMS control for Relays
    By charudatt in forum Code Examples
    Last Post: - 2nd May 2009, 00:08
  4. Reading a SMS to an array
    By KA5MAL in forum GSM
    Last Post: - 17th June 2008, 17:24
  5. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 08:18
