Originally Posted by
camolas
The array is [62] byte the 0 byte in the array is 0 as you can see here "0791539126010000240C91539166392101000080707081934 1400453FA1B0E"
by
OK that makes sense, since you only posted snippets, I wasn't sure you had set up a 62 byte array, and if you did post it all, then woops, I missed it.
EDIT: Yep you did, post 26.
