Siemens c55 sms control help please
Results 1 to 40 of 86
    Quote Originally Posted by camolas View Post
    After de phone recived the AT+CMGR=1 command he gives very fast (1s at most) the
    +CMGR: 1,,23
    0791539126010000240C915391663921010000807070819341 400453FA1B0E
    OK
    Thanks for still caring
    Ok, so don't you think that by pausing for 1/2 second after sending the command, you might miss the incoming data, or at least maybe the beginning of it, thereby causing you to think you might not have gotten anything at all?
    LOOP:
    HSEROUT["at+cpms=",34,"SM",34,13] : PAUSE 500
    HSEROUT ["AT+CMGR=1",13,10] : PAUSE 500
    Ive put HSEROUT["at+cpms=",34,"SM",34,13] and HSEROUT ["AT+CMGR=1",13,10] and them it give me error back, sow back to HSEROUT ["AT+CMGR=1",13,10]:PAUSE 500 and
    HSEROUT["at+cpms=",34,"SM",34,13] : PAUSE 500 and then i thang the HSERIN 5000,POR,[WAIT("OK"),STR myarray\62] to HSERIN 500, .............. data came faster but keep looping
    then to HSERIN 1000,............. same problem
    LOOP:
    Ive put HSEROUT["at+cpms=",34,"SM",34,13] and HSEROUT ["AT+CMGR=1",13,10] and them it give me error back, sow back to HSEROUT ["AT+CMGR=1",13,10]:PAUSE 500 and HSEROUT["at+cpms=",34,"SM",34,13] : PAUSE 500 and then i thang the HSERIN 5000,POR,[WAIT("OK"),STR myarray\62] to HSERIN 500, .............. data came faster but keep looping then to HSERIN 1000,............. same problem
    Just because I'm using l/c letters doesn't mean you have to change yours...
    So what does your program look like now...
    And again, if your phone responds inside of a second, usually faster, and you add in a pause after sending the command that will get a response, what's going to come first, the pause or the response? And are you going to miss it or not?
    This is the last time I am going to state this: DON't use pause statements or ignore the responses of the serial devices. When you send a command ALWAYAS check for the response.-
    Let see if i get it.
    LOOP:
    Change to.
    LOOP:
    HSERIN 5000, [WAIT("OK")]
    Is this what you ment?
    Thanks for caring.
    Thanks for caring.
    Maybe...again, does it work or not?
    Skimask got me on the turn!
    Pheww! Yes at last... 8-)
    Always do this kind of check. It is the only way to communicate. Otherwise you may well be talking but no-one listening!
    Used this
    LOOP:
    HSERIN [WAIT("OK")]
    HSEROUT["AT+CMGR=1",13,10]
    HSERIN [WAIT("OK")]
    POR:
    if myarray[0]="0"then
    '0791539126010000240C91539166392101000080707081934 1400453FA1B0E
    goto success
    goto LOOP
    success:
    High PortD.2
    And it stops in the.
    at+cpms="SM"
    +CPMS: 1,15,1,15,1,15
    OK
    and dont continue
    Wouldn't it be a kick to find out that all of this was being done on some sort of 'simulator' or something?
  1. sms to control pic..pls help...
    By Ziki in forum mel PIC BASIC Pro
    Last Post: - 12th April 2010, 22:19
  2. Replies: 11
    Last Post: - 19th August 2009, 16:23
  3. SMS control for Relays
    By charudatt in forum Code Examples
    Last Post: - 2nd May 2009, 01:08
  4. Reading a SMS to an array
    By KA5MAL in forum GSM
    Last Post: - 17th June 2008, 18:24
  5. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 09:18
