Siemens c55 sms control help please
Results 1 to 40 of 86
    Im lost now
    I think the array is now ok
    myarray var byte[48] 'My array is made i think
    Loop:
    HSEROUT ["AT+CMGR=1",13,10]
    HSERIN 5000, Loop,[WAIT("OK")]
    if myarray[0]="0" then
    if myarray[1]="1" then
    ..................... ' from 0 to 47
    if myarray[46]="46" then
    if myarray[47]="47" then
    goto success
    no_success:
    Goto Loop
    success:
    High PortD.2
    Please give me your input thanks.
    OK. That is an improovment!
    I don't like the loop with Hserin. If you have to do other things and the data arrived are not good, it will stuck in the loop. You must have a way out and do some other checks if you need to execute tasks in the mean time.
    100% right is stuck and keep doing AT+CMGR=1 (see it in hterminal)
    Can you please show me how you do it?
    thanks for caring.
    Its stuck and keep doing LOOP: (see it in hterminal)
    at+cpms="SM"
    +CPMS: 1,15,1,15,1,15
    OK
    AT+CMGR=1
    +CMGR: 1,,23
    0791539126010000240C915391663921010000807070819341 400453FA1B0E
    OK
    There is some error on my code.
     @ Device HS_OSC         ' High Speed Crystal
    define OSC 20     ' Check the spelling of OSC, must be in capital letter
    Include "modedefs.bas" ' Include serial modes
    Define	LCD_DREG	PORTB           'Lcd D 4-bit parallel register starts at PortB.4 to PortB.7
    Define	LCD_DBIT	4
    Define	LCD_RSREG	PORTB
    Define	LCD_RSBIT	2
    Define	LCD_EREG	PORTB
    Define	LCD_EBIT	3
    Define  LCD_COMMANDUS   2000	      ' Command Delay (uS)
    Define  LCD_DATAUS      50 	     ' Data Delay (uS)
    DEFINE  OSC         20                'Define oscilator frequency
    DEFINE LCD_LINES 4 'Number lines on LCD
    DEFINE HSER_SPBRG 129 ' 9600 Baud @ 20MHz, 0.16%
    myarray var byte[62]
    TrisD.2=0
    TrisC.6=0
    TrisC.7=1
    B0 var byte
    High portD.2
    Pause 500
    Low portD.2
    Pause 500
    High portD.2
    Pause 500
    Low portD.2
    Pause 500
    LOOP:
    HSEROUT["at+cpms=",34,"SM",34,13]
    PAUSE 500
    PAUSE 500
    HSERIN 5000, POR,[WAIT("OK")]
    POR:
    if myarray[0]="0"then
    '0791539126010000240C915391663921010000807070819341400453FA1B0E
    goto success
    goto LOOP
    success:
    High PortD.2
    Thanks for caring.
    Quote Originally Posted by camolas View Post
    No kidding...
    Where is myarray getting filled from? And how?
    After this:
    and before that:
    POR:
    you need to fill the array as Skimask stated.
    It is this ok Masters?
    HSERIN 5000, [WAIT("OK")] ' I tacke off the POR from HSERIN 5000, POR,[WAIT("OK")] i think theres no need, is ok masters?
    HSERIN 5000 POR,[STR myarray\62]
    POR:
    Thanks for caring
  1. sms to control pic..pls help...
    By Ziki in forum mel PIC BASIC Pro
    Last Post: - 12th April 2010, 22:19
  2. Replies: 11
    Last Post: - 19th August 2009, 16:23
  3. SMS control for Relays
    By charudatt in forum Code Examples
    Last Post: - 2nd May 2009, 01:08
  4. Reading a SMS to an array
    By KA5MAL in forum GSM
    Last Post: - 17th June 2008, 18:24
  5. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 09:18
