Siemens c55 sms control help please
Results 1 to 40 of 86
    @ Ioannis tanks i will try later.
    Quote Originally Posted by GioppY View Post
    Why not store the messagge in the sim memory card and send with the command "AT+CMSS=n",Cr
    Can you please explain me beter your idea? it will go like this? : Hserout ["AT+CMSS=n", 13]
    n- is posicion number in sim storege?
    no need off [26] Ctrl+z command?
    My code
    Hserout ["at", 13]
    Hserout ["at+cmgs=16", 13]
    Hserout ["079153912601000011000c915391663921010000aa02ef35" , 26]
    I have connect to hterminal and this is what the pic is sending:
    ATAT+CMGS=
    16079153912601000011000C915391663921010000AA02EF3
    It miss a 5 on the end , and 16 is not on the AT+CMGS=16
    Can you hellp me people?
    Here a snip that send a sms from position 1, then wait for ok.
    SerOut2 TX,TTMode,["AT+CMSS=1",Cr] ’invia sms presente in posizione 1
    gosub Poll_Ok ’sms inviato ?
    Search with google "allarme SMS per siemens e pic12f675"
    You should found a my program that uses a siemens C35 and send the message stored in pos.1 from sim card. I do not know if it works with C55.
    Gianni
    Post
    Now is working im very happy )
    code line:
    HSEROUT ["AT+CMGS=16",13,10]
    PAUSE 500
    HSEROUT ["079153912601000011000C915391663921010000AA02EF35" ,26,10]
    HSEROUT [13]
    A good utility to macke sms pdu-encode-decode
    http://twit88.com/home/utility/sms-pdu-encode-decode
    Thanks to the ones that hellp me
    By by
  1. sms to control pic..pls help...
    By Ziki in forum mel PIC BASIC Pro
    Last Post: - 12th April 2010, 21:19
  2. Replies: 11
    Last Post: - 19th August 2009, 15:23
  3. SMS control for Relays
    By charudatt in forum Code Examples
    Last Post: - 2nd May 2009, 00:08
  4. Reading a SMS to an array
    By KA5MAL in forum GSM
    Last Post: - 17th June 2008, 17:24
  5. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 08:18
