Thanks for caring, i have one nokia 6230 but i have tried for one month to connect it to pc but no sucess then i moved to siemens c55 and made it. Can you please just tell me how i have to do (pbp code, because my pdu array works fine in pc connection) to end my pdu array and send the send command (ctrl+z) ??
By by
Hi Norbac. Are you sure it is working? After AT+CMGS= there is a need for " character. Maybe your module does not needed.
Here is an older post I gave as an example:
HSerout ["AT+CMGS=",34,your numbers here,34,13]
hserin 2000,noresp,[wait(">")]
HSerout ["your message here",26]
hSerin 5000,noresp,[wait("OK")]
LCDOut com,1,"Sent OK":Pause 1000
GoTo .....
noresp:
LCDOut com,1,"Message not sent...":Pause 1000
GoTo....
34 is " character
26 is Ctrl+Z character
To Camolas: find another mobile with text. PDU is difficult format. Does not worth it. You may find cheap phones and modules to try.
