ADCIN car battery monitoring
Results 1 to 14 of 14
    Jun 2008
    Default Adcin Battery Monitoring
    Thanks for your replies again guys, you've all been very helpful, what would the 5.1v zener do i know its for protection, it will start conducting around 3.3 v only when D1 as blown what is the purpose of that. For my voltage divider i want to build it with a 10k var in series with a 2.5K, and set the 10k at 5k, this will give me accuracy to tweak out the 5% tolerances. With a peak voltage of 15v which the battery should never get that high the out of my voltage divider will be 5 v. This will give me a wattage of 20 mW for the 5k and 10 mW for the 2.5 k now all this to ask my resistors should not get very hot but would this be enough to change resistance values as they get hotter, so as my resistors get hotter i would lose more and more accuracy or is the wattage so low i should not worry about it. Also is their a way to protect my ADCIN if someone would ever use two batteries and would connect them in series which would give me 24 v and 8 v at the output of my ADCIN, so for that to never happen, how can have no more then 5 v output into my ADCIN to protect it i'm trying to make it as dummy proof as possible. thanks
    Lightbulb
    Hi, Mitch
    Just missing the reverse diode between 7805 In and Out ...
    otherwise schematic is fine for use.
    Default adc
    voltage divider,
    if you consider full-scale voltage to be 25.6 , a 10 to 1 resister ratio, then,
    A) the voltage reading is directly from 8-bit acd value...... 125 would be 12.5 volts
    B) and the applied voltage to PIC is about 2.5 volts
    don
    Jun 2008
    Thanks again guys, why would i need to put a reverse diode between the in and out of my reg, every time i add a diode i lose 0.7 v is it really needed also, what is the purpose of that 5.1 volt zener in their on my opinion that no good my reg needs minimum 6.5v to work.
    Can someone please clarify this for me.
    thanks
    Post
    Hi, Mitch
    see 7805 Datasheet for that : it's for avoiding reverse current flowing through the regulator when input voltage is < output voltage ( typically @ power shutdown ...)
    Note Anode is @ reg output and Cathode @ reg input .... !!!
    Apr 2007
    Quote Originally Posted by mitchf14 View Post
    thanks
    The value of the zener diode is incorrect. For a 12 volt system, a value of 18volts would be more appropriate. I would use a Transorb, not a zener for this task.
    A 12volt automotive system can contain many voltage spikes much higher than the 12 volt battery. The transorb is there to protect the input of the regulator from these spikes.
    If there is a possibility of the input being connected to a 24volt system, I would use a 33v transorb. Also ensure the capacitors on the input of the regulator have a voltage rating of at least 35volts.
    The 10ohm resistor could be replaced with a resettable polyfuse. This way, if the transorb conducts due to overvoltage, the polyfuse will trip and go open circuit. When it cools down again, operation will resume as normal.
    Andy
  1. Adcin charger
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 18th November 2008, 21:49
  2. Voltage monitor for car battery
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2008, 21:47
  3. 12v car battery monitoring
    By oldcarguy85 in forum Schematics
    Last Post: - 10th December 2007, 00:26
  4. Remote Car Starter Safety
    By CocaColaKid in forum General
    Last Post: - 22nd November 2005, 09:10
  5. Using the A/D for Monitoring a Solor Cell and Battery
    By chuck.sieveking in forum mel PIC BASIC Pro
    Last Post: - 13th July 2004, 19:27
