Porta.1 as input
Results 1 to 3 of 3
    Jcee324's Avatar
    Jcee324 Guest
    Default Porta.1 as input
    Hello
    I have a problem with my 16F627 (or with my program). I have done a smal program to drive a stepper motor. The program workes fine until I what to start/stop the motor useing Porta.1 as input. My program code lookes like this:
    'Port A och B
    TRISA = 255
    TRISB = 0
    'Variabler
    Rb0 VAR PORTB.0
    Rb1 VAR PORTB.1
    Rb2 VAR PORTB.2
    Rb3 VAR PORTB.3
    Delay1 VAR BYTE
    Delay2 VAR BYTE
    Delay1 = 10
    Delay2 = 1000
    'Programkod
    Program:
    IF PORTA.1 = 1 Then st2
    IF PORTA.1 = 0 Then st1
    GoTo Program
    st1:
    Low Rb0
    High Rb1
    Low Rb2
    High Rb3
    Pause delay1
    Low Rb0
    High Rb1
    High Rb2
    Low Rb3
    Pause delay1
    High Rb0
    Low Rb1
    High Rb2
    Low Rb3
    Pause delay1
    High Rb0
    Low Rb1
    Low Rb2
    High Rb3
    Pause delay1
    GoTo Program
    st2:
    Low Rb0
    Low Rb1
    Low Rb2
    Low Rb3
    Pause delay2
    GoTo Program
    If I use Portb.4 as the input instead of porta.1 it workes just fine. The motor stopes for one second (delay2) when I push the button connected to pin 10 (portb.4) but when I use porta.1 (pin 18) the motor doesn't stop.
    Does anyone know what I am doing wrong?
    \Jonas
    http://www.geocities.com/jcee324/eindex.htm
    Nov 2004
    Fribourg, Switzerland
    I'm quite new in PICBasic Programming but I think you should set Port A as digital because all MCU with analog input come up in analog mode.
    ADCON1=7
    I think this will solve your problem
    Hans
    Jcee324's Avatar
    Jcee324 Guest
    Talking
    Hello Hans
    Thank you very much! It solved the problem. I just had to change the ADCON = 7 to CMCON = 7 because it's a 16F627.
    Well, thanks again
    \Jonas
  1. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 19:51
  2. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  3. Replies: 11
    Last Post: - 12th July 2008, 03:36
  4. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  5. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
