Surprising 16F628 / 20
Results 1 to 12 of 12
    Jan 2006
    Istanbul
    I had something similar.
    And even tough PORTB.0 = 1 or 0 did not work, interestingly PORTB.0 = PORTB.0 ^ 1 worked.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    another thought ...
    try removing the LEDs and watching the pins with a scope or DMM. If no load works then add more decoupler / filter caps.
    just my 1 cent
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Bombay, India
    Just thinking aloud. I am assuming the 16f628 / 20 in the subject means you are thinking it runs at 20MHz or is it something else? The INTOSC for the 628 is 4MHz. Perhaps you have declared 20MHz for OSC like below. Is this a possible cause?
    define OSC 20
    I do remember having faced a problem like this once before, but unfortunately, I cannot recall what it was and in which project. It too had to do with an LED though. All I remember is that I had to write the port twice with a delay between the 2 writes to get it to behave.
    Hi, Jerson
    It's not a speed issue nor ... I intend to make them run @ 4Mhz !!! ( or so ... the RCINTOSC is somewhat aside the 4Mhz !!! )
    This Pic is just ... 10% under the 4 Mhz !!! ( 136 units for a true 1500 µs pulse ).
    I think we met the same issue ...
    Hi, Bruce
    The Pause time modifying do not change anything.
    Hi, Sayzer
    That's the strange thing ... just the ( let's say ) ASM command doesn't work. A signal rise and fall time issue inside the Pic ???
    Hi, Paul
    Signal is neat and right on the DMM ... only without the Led !
    So, ... I have to try another Pic Sample to confirm !!!
    BTW ... I discovered in MPLAB 8.10 programmer, If you ask for ALL Erase ... The EEPROM is NOT Erased, and you must explicitly ask for FF Writing ...
    same issue in the toolbar's "Erase Flash Device" ...
    to be verified for other processors ...
    Feb 2003
    Smile
    Sounds like it worked - do you have electrolytic decoupler and ceramic filter caps? Is your power clean? Have you reduced ground loops?
    Strange indeed to be sensitive to 12mA load switching ....
    Interested to know how it turns out
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. INT2 anomaly in DT_INTS-18??
    Last Post: - 17th February 2010, 21:07
  2. capture/repeat data ?
    By Sam in forum Serial
    Last Post: - 27th November 2006, 04:19
  3. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 02:31
  4. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  5. SERIN2 not working with 16F628
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 21:37
