Surprising 16F628 / 20
Results 1 to 12 of 12
    Question Surprising 16F628 / 20
    I tried to program a ... simple stupid blinking light ... and it doesn't work ... as it should !!!
    'Configuration
    @	__CONFIG  _BODEN_ON &_CP_OFF & _PWRTE_ON & _WDT_ON & _LVP_OFF & _MCLRE_ON  & _INTRC_OSC_CLKOUT
    	CMCON	= 7
    	VRCON	= 0
    'Initialisation des ports
    	PORTA   = 0
    	PORTB   = 0
    	TRISA = %00000111
    	TRISB = %00000000
    oubli: ' Boucle d'arret si oubli cavalier
    	PORTB.0 = 1
    	PAUSE 200
    	PORTB.0 = 0
    	PAUSE 200
    	GOTO Oubli
    Doesn't work
    But That snippet works fine :
    ( same as previous )
    	HIGH PORTB.0
    	PAUSE 200
    	LOW  PORTB.0
    	PAUSE 200
    	GOTO Oubli
    The load on PORTB.0 is a simple LED drawing 12 mA ...
    Has someone an idea ???
    Bombay, India
    What do you mean - Doesn't work. Can you elaborate your statement? Is the LED always on/off?
    The ellipses before Oubli - is there something that modifies your TRISB in there?
    When you do HIGH / LOW to a pin, PBP also writes the TRIS bit for the pin to the direction you need.
    Hi, Jerson
    Halas, there are no TRIS mods in the whole program ( including PbP commands ).
    Just reading 3 EEPROM locations to verify if the device is ( application ) programmed or not.
    add to that a BUTTON command to verify, if EEPROM unprogrammed, if the programming jumper has been inserted ...
    	TRISA = %00000111
    	TRISB = %00000000
    'Lecture des valeurs en EEPROM
    	READ 1,dureeprog
    	READ 2,side
    	READ 3,neutre
    	IF ( neutre <> 255 ) AND( dureeprog <> 255 ) THEN start
    ' Vérification Présence Cavalier si premičre programmation
    	Delay = 0
    	BUTTON ModProg,0,255,0,delay,1,Mesurepro
    as you can see, I just had cut those "unsignificant" lines.
    I've also verified the ASM lines, but nothing noticeable ...
    the strange thing is I had added those lines just past TRISA and TRISB, to verify PortB ( same LED load + 270 Ohms on each PortB output ) ...
    'Verification PORTB
    '	FOR I = 0 to 7
    '		PORTB.0[i] = 1
    '		PAUSE 300
    '	NEXT I
    '	FOR I = 7 to 0 Step -1
    '		PORTB.0[i] = 0
    '		PAUSE 300
    '	NEXT I
    and it worked well ...
    I've already seen Port outputs not working , like here, but it was when driving large capacitive loads ( 3.5 µF between output and ground !!! ).
    Solution had been using HIGH and LOW ... like here.
    But, Here, it's the first time I see that with LEDs as loads ...
    so, I know what to do ... but really don't understand why !!!
    Read-Modify-Write issues?
    Bombay, India
    I'm not really sure what to make of it. What is the state of LED? On or Off?
    Hi, Jerson
    PORTB.0 = 1 : Led do not work
    HIGH PORTB.0 : Led works fine
    Hi, Ski
    I verified the ASM ... doesn't read anything at all ,here.
    PORTB.0 =  BSF PORTB,0
    HIGH PORTB.0 =  BSF PORTB,0
                           BSF STATUS, 5
                           BCF PORTB,0
                        **Next ASM command** MOVLW 0xC8 ( Pause duration )
                           BCF STATUS, 5
    so, the only "surprising thing" is it writes PAUSE duration in W while addressing page 1 ... but I do not think it should cause any trouble ... I suppose it works like that not to toggle Page twice, if staying on page 1 !
    I'll try the program with XTAL clock ( it's the first time I use INTRC with this snippet ...) ever has worked well till yesterday ... just to see.
    Hi Alain,
    My guess would also be read-modify-write. Try increasing the pause time from 200 to
    1000 in the first version you posted that isn't working. Does it work with the longer
    pause?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2006
    Istanbul
    I had something similar.
    And even tough PORTB.0 = 1 or 0 did not work, interestingly PORTB.0 = PORTB.0 ^ 1 worked.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    another thought ...
    try removing the LEDs and watching the pins with a scope or DMM. If no load works then add more decoupler / filter caps.
    just my 1 cent
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Bombay, India
    Just thinking aloud. I am assuming the 16f628 / 20 in the subject means you are thinking it runs at 20MHz or is it something else? The INTOSC for the 628 is 4MHz. Perhaps you have declared 20MHz for OSC like below. Is this a possible cause?
    define OSC 20
    I do remember having faced a problem like this once before, but unfortunately, I cannot recall what it was and in which project. It too had to do with an LED though. All I remember is that I had to write the port twice with a delay between the 2 writes to get it to behave.
    Hi, Jerson
    It's not a speed issue nor ... I intend to make them run @ 4Mhz !!! ( or so ... the RCINTOSC is somewhat aside the 4Mhz !!! )
    This Pic is just ... 10% under the 4 Mhz !!! ( 136 units for a true 1500 µs pulse ).
    I think we met the same issue ...
    Hi, Bruce
    The Pause time modifying do not change anything.
    Hi, Sayzer
    That's the strange thing ... just the ( let's say ) ASM command doesn't work. A signal rise and fall time issue inside the Pic ???
    Hi, Paul
    Signal is neat and right on the DMM ... only without the Led !
    So, ... I have to try another Pic Sample to confirm !!!
    BTW ... I discovered in MPLAB 8.10 programmer, If you ask for ALL Erase ... The EEPROM is NOT Erased, and you must explicitly ask for FF Writing ...
    same issue in the toolbar's "Erase Flash Device" ...
    to be verified for other processors ...
    Feb 2003
    Smile
    Sounds like it worked - do you have electrolytic decoupler and ceramic filter caps? Is your power clean? Have you reduced ground loops?
    Strange indeed to be sensitive to 12mA load switching ....
    Interested to know how it turns out
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. INT2 anomaly in DT_INTS-18??
    Last Post: - 17th February 2010, 20:07
  2. capture/repeat data ?
    By Sam in forum Serial
    Last Post: - 27th November 2006, 03:19
  3. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 01:31
  4. Code check -- button not working
    Last Post: - 2nd March 2006, 22:43
  5. SERIN2 not working with 16F628
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 20:37
