PORTC instable
Can i help me?
if i write ..
KeyUp:
PORTA = 0
TRISA = %00000000 ^ %00011111
PORTC = 0
TRISC = %10001111
HSEROUT[HEX PORTA, "-", HEX PORTC, 13]
porta = 0
portc instable
i use cap 0,1 vss/vd
Code:Include "modedefs.bas" asm ;__CONFIG _CONFIG1H, _OSC_HSPLL_1H __CONFIG _CONFIG1H, _OSC_INTIO7_1H & _IESO_OFF_1H __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H ;__CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H __CONFIG _CONFIG3H, _PBADEN_OFF_3H __CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L __CONFIG _CONFIG5L, _CP0_ON_5L & _CP1_ON_5L & _CP2_ON_5L & _CP3_ON_5L __CONFIG _CONFIG5H, _CPB_ON_5H endasm @ errorlevel -202 '------------------------------------------------------------------------------- DEFINE HSER_RCSTA 90h DEFINE HSER_TXSTA 20h DEFINE HSER_BAUD 9600 DEFINE HSER_CLROERR 1 '------------------------------------------------------------------------------- I Var WORD J Var BYTE K Var BYTE Lin var byte Col var byte '------------------------------------------------------------------------------- Boot: DEFINE OSC 32 OSCCON = %11110000 ' 8 Mhz, internal osc OSCTUNE = %11000000 ' 4x PLL enabled ADCON0 = 0 ADCON1 = 15 CMCON = 7 INTCON2.7 = 0 LATA = 0 LATB = 0 LATC = 0 PORTA = 0 TRISA = %00000000 PORTB = 0 TRISB = %11111111 PORTC = 0 TRISC = %10001111 Led = 1 pause 2000 hSEROUT ["-"] PAUSE 1 hSEROUT ["Start", 13, 10] pause 1 Led = 0 '------------------------------------------------------------------------------- Main Gosub KeyUp Goto Main KeyUp: PORTA = 0 TRISA = %00000000 ^ %00011111 PORTC = 0 TRISC = %10001111 'HSEROUT[HEX PORTA, "-", HEX PORTC, 13] pause 1 IF (PORTC & %00001111) != 15 THEN KeyUp PAUSE 50 Letra_Down: FOR Lin = 0 TO 4 PORTA = 0 TRISA = (DCD Lin) ^ %11111111 col = PORTC & %00001111 IF (col != 15) THEN Key NEXT lin GOTO Letra_Down Key: Col = (NCD (col ^ %00001111)) while (PORTC & %00001111) != 15 wend hserout[dec lin, "-", dec Col, 13] RETURN '------------------------------------------------------------------------------- End
