LED timing
Results 1 to 6 of 6
Thread: LED timing
    Jun 2008
    Default LED timing
    We are trying to program our PIC 16F88 so that we can time our LED when triggered by a switch. We want the LED to stay on for five seconds everytime the switch is turned on.
    This is the code we have so far:
    DEFINE OSC 20
    TRISB = %00000000 'setup PORTB; 0 for output, 1 for input
    TRISA.0=1
    loop:
    IF PORTA.0 = 1 Then ledon
    PORTB.0=0 'turn off LED
    GOTO loop
    ledon:
    PORTB.0=1 'light LED
    PAUSE 5000 'pause for 2 seconds
    GOTO loop
    We have connected the switch to port A0 and the led to port B0. We would appreciate any help.
    Hello elen-group,
    this should get you started:
    ADCON0 = 0
    ADCON1=0
    CMCON = 7
    ANSEL = 0
    edit: pause 5000 = 5 seconds
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by elen-group View Post
    So, what's the problem?
    Jun 2008
    Our circuit is not conditioned to the switch. Everytime we turn on the circuit our led comes on regardless if we use the switch or not. We tried the suggested help but still did not fix it. I am thinking that there is some issue with the if statement which is not implementing the switch we want.
    DEFINE OSC 20
    PortA = %00000000
    TRISA.0=1
    loop:
    GOTO loop
    ledon:
    GOTO loop
    put a pulldown resistor on porta.0
    and a pullup on PortB.0
    Jan 2006
    Istanbul
    Here, I think, what is needed.
    <font color="#0000FF"><i>'All the usual stuff here.
    </i></font><b>Sw  </b><font color="#000080"><b>VAR </b></font><b>PORTA.</b><font color="#FF0000"><b>0 </b></font><font color="#0000FF"><i>' Switch is connected to RA0.
    </i></font><b>LED </b><font color="#000080"><b>VAR </b></font><b>PORTB.</b><font color="#FF0000"><b>0 </b></font><font color="#0000FF"><i>' LED is connected to RB0.
    </i></font><b>Flag </b><font color="#000080"><b>VAR BIT    </b></font><font color="#0000FF"><i>' Use a flag to have a virtual falling-edge,rising-edge thingie.
    </i></font><b>Begin:
        </b><font color="#000080"><b>INPUT </b></font><b>Sw    </b><font color="#0000FF"><i>' Switch pin is an input pin. Tie it to V+ with a resistor.
        </i></font><b>Flag = </b><font color="#FF0000"><b>0
    </b></font><b>Loop:
    </b><font color="#0000FF"><i>' When button is pressed, the LED turns ON, stays ON 5 secs and then turns OFF.
    ' While button is being pressed, the led does NOT repeat Turn ON action.
    ' When the button is released then Flag is cleared. Thus, what happens?
        </i></font><font color="#000080"><b>IF </b></font><b>Sw = </b><font color="#FF0000"><b>0 </b></font><font color="#000080"><b>AND </b></font><b>Flag = </b><font color="#FF0000"><b>0 </b></font><font color="#000080"><b>THEN </b></font><b>LedOn      </b><font color="#0000FF"><i>' SW is pressed.
        </i></font><font color="#000080"><b>IF </b></font><b>Sw = </b><font color="#FF0000"><b>1 </b></font><font color="#000080"><b>AND </b></font><b>Flag = </b><font color="#FF0000"><b>1 </b></font><font color="#000080"><b>THEN </b></font><b>Flag = </b><font color="#FF0000"><b>0   </b></font><font color="#0000FF"><i>' SW is released.
    </i></font><font color="#000080"><b>GOTO </b></font><b>Loop
    LedOn:
        LED = </b><font color="#FF0000"><b>1     </b></font><font color="#0000FF"><i>' Turn ON led.
        </i></font><font color="#000080"><b>PAUSE </b></font><font color="#FF0000"><b>5000  </b></font><font color="#0000FF"><i>' Wait 5 secs.
        </i></font><b>LED = </b><font color="#FF0000"><b>0     </b></font><font color="#0000FF"><i>' Turn OFF Led.
        </i></font><b>Flag = </b><font color="#FF0000"><b>1
        </b></font><font color="#000080"><b>GOTO </b></font><b>Loop
    </b><font color="#000080"><b>END
    </b></font>
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  3. For next loop using: Led var Byte
    By quester in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 10:16
  4. LCD will not start
  5. can't even flash an LED
    By bruno333 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 13:27
