PIC16F887 and DS1307
Results 1 to 22 of 22
    Default rtc
    control register may need to be set
    alsoooooo....
    the I2c read and write address/control string have to be different, I just used binary 00011110 (just an example) to make sure the read write is correctly coded.
    don
    Jun 2008
    tried that already. It doesn't help.
    What do you mean by "the I2c read and write address/control string have to be different" ?
    Default rtc
    RTCADW CON %11010000 'DS1307 RTC ADDRESS SEND...RECEIVE
    RTCADR CON %11010001
    I2CWRITE SDA,SCL,RTCADW,7 ,%00010011 'TURN ON SQU WAVE OUT 32k HZ
    I2CREAD SDA,SCL,RTCADR,0,[RTC[1],RTC[2],RTC[3],RTC[4],RTC[5],RTC[6],RTC[7]]
    from my rtc stuff
    don
    Jun 2008
    Ok, So I tried to use your example.
    Still getting '0' when reading. If i use 10K resistors on the SDA and SCL I get '16'
    INCLUDE "modedefs.bas"
        RTC     VAR BYTE[8] ' Data byte array
    SDA var PORTC.4
    SCL var PORTC.3
    I2CWRITE SDA,SCL,RTCADW,7,%00010011 'TURN ON SQU WAVE OUT 32k HZ
    ;I2CREAD PORTC.4,PORTC.3,%11010000,$00,[RTCSec]
    SEROUT PORTC.6,6,[254,1]
    toggle PORTD.7 : pause 1000
    SEROUT PORTC.6,6,[254,128,#RTC[1]]
    well,
    data on 1307 is hex so.......
    SEROUT2 PORTA.0,6,1,[ "_T" ,HEX RTC[6],"/",HEX2 RTC[5],"/20",_
    HEX2 RTC[7]," , ",HEX RTC[3],":",HEX2 RTC[2],":",HEX2 RTC[1]," ",RTC[9],"M _" ]
    ( use your own port etc.)
    the voltage on SCL & SDA (to gnd) has to be +5 at rest, no signal . Thats what the 10k resisters do.
    also, you can check square wave out at 1 HZ with led/resister on the output pin of 1307 as visual check of rtc.
    I2CWRITE SDA,SCL,RTCADW,7,%00010000 'TURN ON SQU WAVE OUT to...1... HZ
    PBP handles the R/W bit for you just like it says in the manual...so...
    RTC CON %11010000 'DS1307 RTC ADDRESS SEND...RECEIVE
    SDA var PORTC.4
    SCL var PORTC.3
    I2CWRITE SDA,SCL,RTC,7,%00010011 'TURN ON SQU WAVE OUT 32k HZ
    I2CREAD SDA,SCL,RTC,0,[RTC[1],RTC[2],RTC[3],RTC[4],RTC[5],RTC[6],RTC[7]]
    Jun 2008
    well,
    I can't get any signal on the SWQE output, not by LED or by the logic analyzer of the PICkit2. So I might guess the 1307 is malfunctioning.
    This is what I get when analyzing the SCL vs SDA
    This is what I get when analyzing the SCL vs SWQ
    This is what I get when analyzing the SCl vs SDA
    Here are a few things that 'may' help;
    1. If you're using an oscillator >8MHz, then you'll want to include DEFINE I2C_SLOW 1
    since the 1307 max clock speed is 100kHz.
    2. The SQW output is an open-drain type. I.E. it cannot output a logic 1. Use a 10K
    pull-up on the SQW output. Then you should see a square wave output on your scope.
    3. Use the external pull-ups on SDA and SCL.
    4. Connect a 3V battery to the 1307 Vbat input.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Pic16f887 vs ds1307
    By larzazral in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 05:12
