18F1220 programming problem
Results 1 to 9 of 9
    Default 18F1220 programming problem
    I am trying to run Darrel Taylor's "Hello World" program. It compiles, but when trying to program, I get the following message:
    "MicroCode Studio is unable to locate 'DT Hello World.hex'. Do you want to compile and assemble 'DT Hello World.pbp' now?" When I answer yes, it appears to compile, but the ME Labs U2 programmer window does not come up. What am I doing wrong? Code:
    TRISA = %00100000
    TRISB = %00000111
    WDTCON = 0
    ADCON0 = %00000000
    ADCON1 = %01111111
    LVDCON = %00000000
    CCP1CON = %00000000
    OSCCON = %01100010
    RCON = %10000010
    EECON1 = %00000100
    INTCON2 = %00000000
    INTCON3 = %01011011
    PIE1 = %00000000
    PIE2 = %00000000
    IPR1 = %00000000
    IPR2 = %00000000
    RCON = %10000000
    T1CON = %00000000
    T2CON = %00000000
    T3CON = %00000000
    TXSTA = %00000000
    RCSTA = %00000000
    LVDCON = %00000000
    @ __CONFIG _CONFIG1H, _IESO_OFF_1H & _FSCM_OFF_1H & _INTIO2_OSC_1H
    @ __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _BORV_27_2L
    @ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_32K_2H
    @ __CONFIG _CONFIG3H, _MCLRE_OFF_3H
    @ __CONFIG _CONFIG4L, _DEBUG_OFF_4L & _LVP_OFF_4L & _STVR_OFF_4L
    @ __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L
    @ __CONFIG _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    @ __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L
    @ __CONFIG _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    @ __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L
    @ __CONFIG _CONFIG7H, _EBTRB_OFF_7H
    LED1 VAR PORTB.4
    INCLUDE "DT_INTS-18.bas" ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts
    INT_Handler INT_INT, _ToggleLED1, PBP, yes
    @ INT_ENABLE INT_INT ; enable external (INT) interrupts
    PAUSE 1
    GOTO Main
    '---[INT - interrupt handler]---------------------------------------------------
    ToggleLED1:
    TOGGLE LED1
    @ INT_RETURN
    Thank you for any help.
    Try shortening the name itself, keep it under 8 characters, and possibly the path too, just to see what happens...
    Other than that, looks like an MCS configuration problem.
    I failed to mention: Other programs I have written for this part compile and program just fine, so it must have something to do with Instant Interrupts.
    Quote Originally Posted by jderson View Post
    So it must know where Hello World is. It can't find the hex file...ok...it didn't compile fully the last time, and therefore didn't produce a .hex file.
    The U2 programmer (or any other programmer) is an add-on to MCS and must be configured as such, either with the correct command line or at least with the correct options in MCS.
    If the file compiled with errors in MCS, you would see other error messages at the bottom of the MCS screen, and most likely, if you think the error has something to do with the instant interrupts, the error would most likely have the words 'instant interrupts' in it.
    But you didn't say anything about that, so I think I can safely assume you haven't connected MCS to the programmer correctly as of yet.
    Or were there more errors?
    I get the "Overwriting previous address contents" (Error 118), but as I said, other programs also give these error messages and still compile and program correctly.
    Hello jderson,
    It compiles perfectly for me after commenting out the STD configs in the 18F1220.inc file and finds my programmer too, loads the hex too, My money is on Darrel's code is NOT at fault. EDIT: LVDCON = %00000000 is listed twice too
    applies to the overwriting problem
    Thanks Joe! Indeed, the CONFIF1H line is the offender. I don't understand why, but I'll find out.
    CONFIF1H? Huh?
    I'm guessing here, 'cause I haven't/can't look at the 18f1220 inc file at the moment, but the link to the post above most likely will fix your problem.
  1. 16F676 programming problem
    Last Post: - 18th May 2009, 17:39
  2. PIC18F4620 Programming problem
    By JavPar in forum mel PIC BASIC Pro
    Last Post: - 6th December 2008, 04:21
  3. PIC 18f1220 EUSART Baud Rate Cache Problem
    By wklose99 in forum Off Topic
    Last Post: - 15th April 2008, 00:39
  4. Programming Problem with PIC16F819
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 24th July 2007, 18:42
  5. Problem programming the PIC16F648A
    By Edgardo_2 in forum General
    Last Post: - 29th December 2006, 00:02
