This is adapted from the thread ...
32-bit Variables and DIV32, Hourmeter 99999.9
http://www.picbasic.co.uk/forum/showthread.php?t=1942
Should work, but I haven't tested the modification.
HTH,Code:BigVar VAR WORD[2] ; 32-bit (Dword) Var1 VAR BigVar(1) Var2 Var BigVar(0) Result Var Word Remainder Var Word ;----[Load a 32-bit (Dword) variable into PBP registers, Prior to DIV32]----- Asm PutMulResult?D macro Din MOVE?BB Din, R2 MOVE?BB Din + 1 , R2 + 1 MOVE?BB Din + 2, R0 MOVE?BB Din + 3, R0 + 1 RST?RP endm EndAsm ;====[Simple loop to test Big Numbers]======================================= Start: Var1 = 1 Var2 = %1111101111010000 MainLoop: LCDOUT $FE,1 ; clear screen Gosub ShowBigNumber PAUSE 1000 Var2 = Var2 + 1 if Var2 = 0 then Var1 = Var1 + 1 goto MainLoop ;=========================================================== ;----[Display 32-bit value with 2 decimals using LCDOUT]--------------------- ShowBigNumber: @ PutMulResult?D _BigVar Result = DIV32 1000 Remainder = R2 LCDOUT $FE, 2 ; Home Cursor IF Result > 0 then LCDOUT Dec Result, DEC1 Remainder/100,".",DEC2 Remainder//100 else LCDOUT DEC Remainder/100,".",DEC2 Remainder//100 endif return
