two variables on LCD
Results 1 to 5 of 5
    Jun 2006
    Default two variables on LCD
    I have two variables
    Var1 var word
    Var2 var word
    The var1 is always 1 and the var2 is anything from 0 to 65535.
    var1 = 00000000 00000001
    var2 = 11111011 11010000
    var1 + var2 = 00000000 00000001 11111011 11010000
    Decimal = 130000
    I want to show on LCD as Result = 1300,00
    How to show the result on LCD;
    Cool
    Quote Originally Posted by savnik View Post
    Var1 var word
    Var2 var word
    Decimal = 130000
    Here we go again...
    1) Get the update for PBP 2.50A. Handles LONG (31 bit variables, +/- 2,000,000,000)
    2) Split the variable up the hard way...
    original var1 = $1
    original var2 = $fbd0
    Add a small subroutine in your program to make it so that each word 'handles' 4 digits, so you end up with:
    varhigh var word 'in this case it will be 0
    varmed var word 'in this case should end up with 0013
    varlow var word 'in this case should end up with 0000
    Shouldn't be THAT hard.
    This is adapted from the thread ...
    32-bit Variables and DIV32, Hourmeter 99999.9
    http://www.picbasic.co.uk/forum/showthread.php?t=1942
    Should work, but I haven't tested the modification.
    BigVar    VAR WORD[2]    ; 32-bit (Dword)
      Var1    VAR BigVar(1)
      Var2    Var BigVar(0)
    Result    Var Word
    Remainder Var Word
    ;----[Load a 32-bit (Dword) variable into PBP registers, Prior to DIV32]-----
    Asm
    PutMulResult?D macro Din
        MOVE?BB   Din, R2
        MOVE?BB   Din + 1 , R2 + 1
        MOVE?BB   Din + 2, R0
        MOVE?BB   Din + 3, R0 + 1
        RST?RP
    EndAsm
    ;====[Simple loop to test Big Numbers]=======================================
    Start:
        Var1 = 1
        Var2 = %1111101111010000
    MainLoop:
        LCDOUT $FE,1        ; clear screen
        Gosub ShowBigNumber
        PAUSE 1000
        Var2 = Var2 + 1
        if Var2 = 0 then Var1 = Var1 + 1
    goto MainLoop
    ;----[Display 32-bit value with 2 decimals using LCDOUT]---------------------
    ShowBigNumber:
    @   PutMulResult?D  _BigVar
        Result = DIV32 1000
        Remainder = R2
        LCDOUT $FE, 2            ; Home Cursor
        IF Result > 0 then
            LCDOUT Dec Result, DEC1 Remainder/100,".",DEC2 Remainder//100
            LCDOUT DEC Remainder/100,".",DEC2 Remainder//100
    HTH,
    Jun 2006
    Smile
    Thank you Darrel.
    It's work fine.
    Only i put out the two lines
    Var2 = Var2 + 1
    Var2 = Var2 + 1
    Exactly what you should have done.
    Thanks for the update.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  5. LCD will not start
