XTR-434 transceiver
Results 1 to 17 of 17
    What about your non-working code?
    Default answer
    ...i've found some failures in my schematic...so i have redrawn it
    here is the link
    Transmitter Schematic
    at the time i have no code because i am using Windows terminal but i think i must write a program because i've found out that a preamble (of 01010101...) is needed
    do you see any other failures??
    You need not only a 2ms at least preamble but also some kind of data encoding to keep the balance of the 1 and 0 to 50%. So Terminal will not help much except if you can transmit the character with this binary number: 10101010 or 01010101.
    That means definetly Manchester or Biphase encoding as it is the easiest to implement.
    Do a search on the forum and many answers on the topic Manchester will be found (mine too!).
    Please re-read the data sheets of the XTR. Answers included!
    By the way, you new schematic, I believe will ton work! XTR is supplied through a capacitor and data are fed through 10K and 100K resistors. Are sure about the values? I'd rather choose your first one.
    i have asked a friend who corrected my schematic like this....
    what do you think
    Good. Now see the other issues as described previously.
    Check this also:
    http://www.picbasic.co.uk/forum/showthread.php?t=198
  1. Transceiver ER900TRS Easy Radio
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 17th August 2008, 12:25
  2. RF Transceiver modules help
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 15:54
  3. Tws 434/ Rws 434
    By jmbanales21485 in forum Serial
    Last Post: - 29th July 2007, 07:04
  4. 2.4Ghz Transceiver Module (TRW-24G)
    Last Post: - 28th June 2006, 16:16
  5. Aurel XTR 434 transceiver
    By Eng4444 in forum Schematics
    Last Post: - 7th May 2006, 23:07
