Thanks for the link Trent. It will take me a little time to learn the file stuff for Planetsource. For now could I use the link you set up for me? Should these thread discussions be moved to say 'off topic' and just keep adverts here?
don
don
The link is yours for as long as you need it, or until I require the bandwidth (not likely for a while)
FYI: Your file has had 133 hits in just over a week. This equates to about 50MB of bandwidth. I can allow for up to a maximum of 100MB of bandwidth p/month for your file, if it exceeds this, I will have to suspend the link until the start of the next month. I don't recommend that you go posting the link around on too many forums.
Trent Jackson
Thanks Trent,
I will figure out where to shove my file when your bandwidth runs out of gas.
don
You should be fine as long as you only have the link on this forum. Bigpond is the Rolls Royce ISP in Australia (personal opinion), but at 13 cents p/mb after you exceed your monthly limit, this also makes them the most expensive!
Trent Jackson
