Using PIC as a Low Voltage Meter, need help
Results 1 to 13 of 13
    Jun 2008
    Eastern USA
    Default PIC Voltmeter
    Thanks Jerson,
    Heres the schematic of a PIC 16F876A with a LCD display showing 2 lines, able to output 2 voltages as i need.
    This looks like what i need, i cant get any responce form the site that has posted this schematic!
    Its a pleasure to get a responce to the question, thanks again Jerson.
    Cool
    Hi, Doable
    I think a look to the SAMPLES folder of your PbP CD will show you how to deal with the PIC A/D converter ... and display the result.
    search for "ADCin xxxxx.bas"
    The link you gave only allows ( with buying the '876 ) a 0 - 7v range ... by changing the input divider ratio.
    These examples are for '877 and '876 ... surprise !
    Jun 2008
    Eastern USA
    Smile
    Hello Alian,
    I am using Microchip PICkit-2 and MPLAB, are the SAMPLES folders you speak of on those disk? If not wher can i get the sample folders of PbP CD?
    Alain gave you the direction, to your legal obtained CD. Are a legal owner?
    Wink
    Hi, Ioannis
    As those files are free to download for every one ... and considering our friend's profile ...
    let's give this link without any indiscreet further question ...
    http://www.melabs.com/resources/samples.htm
    Okie-dokie Alain...
    Jun 2008
    Eastern USA
    Smile
    Thanks Alian for the information,
    I dont want to sound stupid but i have little experance in the PIC world, but have a great thurst to learn. Now with the system i am using are the code examples compatable. I have done enough to have learned that even between different PIC the basic code changes, I dont understand Microchip's reason for that.
    I will attemp to write to a PIC16F877A the sample code for the voltage meter, I am sure that i have more questions later on. Thanks again for helping with this!
    Cool
    Probably never seen the 'little green book' either...
    Wink
    Hi, Ski
    As Mel said ... let's be helpful, ... !!!
  1. The PIC does not start its program.
    By Ted's in forum Off Topic
    Last Post: - 28th July 2008, 09:22
  2. Serial Question + General Review
    By Freman in forum General
    Last Post: - 20th June 2008, 22:27
  3. Problems with RC2 and RC3
    Last Post: - 29th May 2006, 17:19
  4. PIC16F84(A) counter
    By nmmr in forum mel PIC BASIC Pro
    Last Post: - 26th May 2005, 04:27
  5. Low Voltage Detect
    By Brian in forum mel PIC BASIC Pro
    Last Post: - 1st April 2005, 16:46
