ok thanks steve, r/w pin is on ground, modified code and circuit to give
;LCD test Program
; Set LCD Data port
DEFINE LCD_DREG PORTC
; Set starting Data BIT (0 OR 4) IF 4-BIT bus
DEFINE LCD_DBIT 0
; Set LCD Register Select port
DEFINE LCD_RSREG PORTC
; Set LCD Register Select BIT
DEFINE LCD_RSBIT 4
; Set LCD Enable port
DEFINE LCD_EREG PORTC
; Set LCD Enable BIT
DEFINE LCD_EBIT 5
; Set LCD bus size (4 OR 8 bits)
DEFINE LCD_BITS 4
; Set number of lines ON LCD
DEFINE LCD_LINES 4
DEFINE LCD_COMMANDUS 2000
; Set Data delay time in us
DEFINE LCD_DATAUS 50
TRISA = 0
TRISC = 0
cmcon0 = 7
ansel = 0
loop:
Pause 1500
LCDOut $FE,1,"Hello" ; Clear display AND show “Hello”
LCDOut $FE,$C0,"World" ; Jump TO second line AND show “World”
GoTo loop
also, i tested the contrast and got nothing. increased it to 9v. zilch
do you think it is a knackered module???
cheers
