Extreme Noobie question 12F675
Results 1 to 12 of 12
    Jun 2008
    Spokane, WA
    Default Extreme Noobie question 12F675
    Hey, I am trying to learn how to use the button command but I have not been able to get it to work. My workaround is not working either. What I want to do is start the flashing loop on GP0 after the button on GP1 is pushed. I think my problem is in the Loop1 but I dont know how to fix it. It just goes directly to flash loop2.
    Can anyone show me how to do this using the button command? I will keep trying but it just passes it right up.
    Jeff
    'INITIALIZE PINS and PORTS:
    SYMBOL ANSEL = $9F '$19 IS ANSEL REGISTER
    POKE ANSEL, 0 'MAKE PIN DIGITAL, NOT ANALOG
    SYMBOL ADCON0 = $1F 'TURN OFF A/D ON PIN4. (DEFAULT IS ON)
    POKE ADCON0, 254 '$1F IS ADDR OF A/D REGISTER. 10011111 (7)
    'ARE BITS TO TURN A/D ON AND OFF
    SYMBOL TRISA = $85 'SETUP PINS DATA DIR I/O
    POKE TRISA, 255 'MAKE DATA I/O GP0 AN OUTPUT, GP1 AN INPUT
    'AND MAKE GP1 AN INPUT (ALL OTHERS ARE OUTS)
    symbol PORTA = $05 '$05 IS OUTPUT DATA REGSITER
    POKE PORTA, 0 'TURN OFF ALL BITS
    Loop1: PEEK PORTA, BIT0 'COPY PORTA REG, PUT IN VARIABLE B0
    IF BIT0 = 1 THEN LOOP1 'WHEN BUTTON IS PUSHED, INPUT GOES LOW
    loop2: High 0 'Turn on LED connected to GP0
    Pause 500 'Delay for .5 seconds
    Low 0 'Turn off LED connected to GP0
    Goto loop2 'Go back to loop and blink LED forever
    ? #1 - Are you using PicBasic or PicBasicPro? I assume PicBasic. Which version?
    PIC12F675 doesn't have PortA, it's got GPIO.
    But I see you're using TRISA/PORTA as an alias for GPIO...
    Do you have a pullup resistor on the button? Is it connected to Vdd or Vss directly? Does it float if the button isn't pressed?
    How about trying something like this:
    POKE $9f,0:POKE $1f,254:POKE $85,255:symbol PORTA=5:POKE PORTA, 0
    Loop1: PEEK PORTA, B0 'COPY PORTA REG, PUT IN VARIABLE B0
    IF B0 = 1 THEN HIGH 0
    IF B0 = 0 then LOW 0
    goto loop1
    The ONLY thing that happens here is that the LED follows the button...that's it. Nothing else..
    At least that's the only thing that SHOULD happen...
    Last edited by skimask; - 23rd June 2008 at 07:58. Reason: Duh factor kicked in...
    Jun 2008
    Spokane, WA
    Hey, thanks for answering, skimask. I am running PICBASIC 2.3.0.0. My button is pulled up with thru a resistor, so when button is pressed, pin goes low - to ground.
    I could not compile your code. Maybe I am missing something:
    POKE $9f,0
    POKE $1f,254
    POKE $85,255
    symbol PORTA=5
    POKE PORTA, 0
    goto loop1
    It gets stuck on the "IF B0" lines. Couple more questions: Can I address the pins on this chip using "GPIO". You mentioned that I was using PortA. Maybe it is the same thing; Port A being used on IC's with more than one port? (sounds like maybe I answered my own Q but gotta ask.) Also, how do you make the code quote box? Thanks in advance!
    Jeff
    Quote Originally Posted by Jeff View Post
    POKE $9f,0
    POKE $1f,254
    POKE $85,255
    symbol PORTA=5
    POKE PORTA, 0
    goto loop1
    Jeff
    Hi Jeff,
    I have not used PBC but I tell ya what I think: Change PEEK PORTA to PEEK GPIO.5 and POKE PORTA to POKE GPIO.5 and lose the symbol PORTA=5, I think your compiler is really looking for PortA which is unsupported for this chip. WOW glad I bought the pro version this looks a lot tougher to use.
    PicBasic 2.30 huh? I don't see that option on the MeLabs upgrades page...
    http://www.melabs.com/support/upgrade.htm
    Unless the MeLabs page is wrong, the 12F675 isn't support until version 1.44 of PicBasic...and isn't supported until version 2.42 for PicBasicPro.
    So again...
    Which version do you have?
    Where'd you get it?
    Why not spend the $25 for the upgrade to the latest greatest?
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Hi Jeff,
    I have not used Pic Basic Compiler for almost 10 years but here are some comments and items to check/change to get you going.
    this looks good except your comment is for CMCON not ANSEL (see below)
    you do not need to fiddle with ADCON0 unless you want to use the A2D module. You should leave these two lines out. As it stands now, these two lines set up the A2D to acquire AN3 using a reference voltage on pin GP1, which might be messing you up. The pins do default to analog but changing them to digital is accomplished with ANSEL and CMCON.
    You need to disable the comparators so add something like this
    SYMBOL CMCON = $19 '$19 IS CMCON  REGISTER
    POKE CMCON, 7 'MAKE PIN DIGITAL, NOT ANALOG
    Here the poke 255 is actually making everything inputs. If you want everything to be inputs except GP0, then poke 254
    symbol PORTA = $05 '$05 IS OUTPUT DATA REGISTER
    turns off all outputs so okay
    you need to peek porta into a byte sized variable. Try PEEK PORTA, B0 as noted in your comment
    this does check bit 0 of B0 but you wanted GP0 to be an output? Maybe you want to check the bit where your switch is connected.?
    this trap looks good.
    One last comments - Ski is correct, it is strange to rename the GPIO port to PORTA. Consider changing all PORTA refs above to GPIO. The same goes for TRISA - change to TRISIO
    reply back with progress for more help
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    France
    Default 12F675 study
    Hello
    First, I have made a search on that PIC but I didn't find any answer on the following questions :
    1/ Am I right if I say that the VSS and VDD pins are not in the same way than the well known 16F84 ?
    we must make an adaptator to use a JDM programmer and having RB6 (pin 12) and RB7 (pin 13) pins on pin 7 and 6 on the 12F675 (assuming that we reverse VSS and VDD) and take pin 4 of the 16F84 to pin 4 on the 12F675 ! hope it is clear !
    2/ we must read first the 12F675 to store oscal and bandgap datas ?
    3/ we must play with CMCOM and Ansel command to have Digital port instead of analog status a power on time. (same story than for 16F628 or 16F88)
    4/ we must forget PORTA and use GPIO to declare activ pins ?
    5/ we must modify HEX file to feed oscal and bangap datas before programming ?
    if I can find the famous BLINK.BAS program for 12F675, I will save time ...
    what else ? nespresso pub ?
    thanks
    Francois
    Aug 2005
    Houston, TX
    I never found the button command worth the trouble. I just insert a short pause to eliminate bounce problems. 10 - 15 ms.
    Quote Originally Posted by F1CHF View Post
    Hello
    Correct ! Look at the data sheet for the proper connections, 16f84 has some family members who's power connections are the same . . . 16f628 series . . . others are different 16F690 for example.
    Depends upon your programmer, the PICKit2 offers you a choice at programming time whether or not to overwrite.
    Correct ! You need to consult the data sheets for each PIC you are using. You (CAN) open the inc file for the chip you are using and read which registers appear there, you will find those files in the MPASM Suite's root directory.
    Usualy the 8 pin devices use GPIO, I think there is one that uses PortA
    I never have done this, I am sure it is possible, but not necessary unless you are hacking someone's hex file to fit a different chip.
    Sep 2009
    Angry Same problem
    I'm having the same problem with a 12F675 reading a pin
    I'm using PicBasic, Microcode studio and MeL:abs Programmer , latest updates
    I've been trying for a week with different combinations of peeks, pokes and button commands. It runs fine, but ignores my input to shorten the run loop.
    Here is my latest try using he button command with peek and pokes commented out.
    '* Name : Test.BAS *
    '* Author : Gene Choin *
    '* Notice : Copyright (c) 2009 *
    '* : All Rights Reserved *
    '* Date : 9/20/2009 2:13 *
    '* Version : 1.0 *
    '* Notes : TEST for 12F629 Input *
    'TEST program for reading input on pin 1 (Physical pin 6 on 12F629 = GPIO1).
    'pin1 has a 24K pull up resistor to 5V and switch to ground.
    'If pin1 = 0, flash pin 4 and retest.
    'If pin1 = 1. flash pin 5 also and then GOTO TEST
    Symbol CMCON = $1f 'Alias $1f to CMCON
    Poke CMCON, 7 'makes all digital I/O
    'Variables
    'Ports
    Output 0 'Make GP0 the Strike output
    Input 1 'Make GP1 the Run Sense in
    Output 2 'Make GP2 the Filament Drive out
    Input 3 'Make GP3 the MCLR in
    Output 4 'Make GP4 the START LED out
    Output 5 'Make GP5 the RUN LED out
    'Begin Program
    TEST:
    pulsout 4,2000 'Marker - Pin 4 for 4 sec
    High 4
    Pause 4000
    Low 4
    Let B0 = 1 'clear B0
    BUTTON 1,0,0,0,B0,0,Fil_hi 'If switch goes low, goto FilHi- skip High 5
    High 5 'Marker - Pin 5 for 4 sec
    pause 4000
    Low 5
    Fil_HI:
    High 2
    Pause 4000 'Marker - Pin 2 for 4 sec
    Low 2
    GOTO TEST
    CMCON is at address $19
    And if you are using a 12F675, you'll also need to set ANSEL($9F) to 0.
  1. Still 12F675 question
    By F1CHF in forum mel PIC BASIC Pro
    Last Post: - 7th August 2009, 22:09
  2. Noobie Question
    By mel4853 in forum mel PIC BASIC
    Last Post: - 2nd July 2006, 13:45
  3. 12F675, MPLAB programming question
    By EASY in forum General
    Last Post: - 2nd April 2006, 20:28
  4. 12f675 programming question
    By puggy in forum General
    Last Post: - 1st December 2004, 00:34
  5. 12f675 internal osc question.....
    By Gabe@SPdFtsh in forum mel PIC BASIC Pro
    Last Post: - 6th January 2004, 07:33
