The basics
Results 1 to 15 of 15
Thread: The basics
Threaded View
  1. #9
    Quote Originally Posted by malc-c View Post
    So its the lower half of a byte - having 8 bits
    So it follows that we can set values for ADCON, CMCON etc much the same way as we can set which pins are inputs and outputs on each port eg PORTB=%00000000
    yes it does help and I appreciate the effort to post in such detail
    1) Yes - lower half, the lower 'nybble', bottom 4 bits...
    2) Yes, that's exactly the case! Almost everything in the PIC10/12/14/16/17/18 world (in general, the small microcontroller world) is based on the BYTE...8 bits...2 nybbles...left to right = most significant to least significant (gotta be careful when you start playing with WORDs, QUADs, LONGs, etc. Some MCU's don't order them the same in memory, little endian vs. big endian).
    Detail - I got on a roll, a rambling roll. Hopefully that little lecture will catch on and other 'less experienced' folks will read and comprehend it.
  1. Bitwise operations and masks: basics, help?
    Last Post: - 19th April 2008, 01:24
  2. IR software & hardware basics
    Last Post: - 6th May 2007, 11:05
  3. basics programming
    By olivierb38 in forum General
    Last Post: - 18th February 2007, 19:56
  4. Timers, oscillators, cycles... need basics please
    Last Post: - 24th October 2006, 19:33
  5. SERIN basics
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 19:37
