LOL - well I'm try. I know that to get help here it helps if one can be seen to be doing the basics, such as RTFM... even though I may not fully comprehend it
So its the lower half of a byte - having 8 bits
So it follows that we can set values for ADCON, CMCON etc much the same way as we can set which pins are inputs and outputs on each port eg PORTB=%00000000
yes it does help and I appreciate the effort to post in such detail
Yup - that helps a lot. Like I said its been a while since I programmed these things and as I get older I seem not to be able to retain things as easily as I used to
