Trying to find my way
Results 1 to 12 of 12
    Jun 2008
    Unhappy Trying to find my way
    Hi everyone, I need a lot of help, I got MCSP 3.0.0.5, PBP 2.50 on a machine running Vista.
    First, when compiling the code I was getting a "fatal out memory error", I uninstalled both applications and reinstalled again, now I when I try to compile I get "file access denied" and no compiler installed.
    Please someone help before I loose all my hair.
    Thank you.
    Quote Originally Posted by PIC_LOCO2 View Post
    Thank you.
    Probably didn't install the software with admin rights.
    Check the book about the "fatal out of memory error"
    Don't put all your files in the "My Documents" folder. Put the stuff closer to the root.
    Sometimes these programs don't like file path's that are over about 60-ish characters long.
    Jun 2008
    Default Thank you
    I tried that still have the same error message, thank for the input, been out of town, sorry for the long delay.
    Dec 2005
    So Cal and loving it
    I have the same setup as you and it all went on fine.
    If you have tried installing with admin rights and tried running with admin rights, the only other thing I can think of is.....
    Are you running Vista 64 bit? I have the 32 bit version. I know the 64 bit is a lot more strict when it comes to program rights etc. Also did you install to the standard program directory or did you select a new one.
    Other than that, I dont have any other ideas. The file access denied does seem to be a rights managment issue, I do have a Vista 64 machine but the CD/DVD drive is out. If I can find a way to install the progs, I will give it a go and see if they run.
    Paul
    | PBP 2.47/2.50 | MCS+ 3.0.0.5 | U2 Prog | Vista x64 | NO SLEEP!!!!!!! |
    Jun 2008
    Default Thank you
    I'm running Vista 32, I removed both programs and reinstalled again, still have the same error, getting a bit frustrated , don't know what else to do.
    fc
    Dec 2005
    Default another question
    I removed the MCS+ link to pbp and when I tried to compile something it did a search and found it - so if it is still saying no compiler etc, it is either not in the standard directory or it is in the progrram files folder and MCS+ does not have the rights to access it.
    Here are some questions so I know whats going on a little better:
    Where is pbp installed?
    Where is MCS+ installed?
    Did you install MCS+ using admin rights? or
    Did you run MCS+ using admin rights?
    Are you an admin user on the PC?
    Hang in there, well get it.
    Paul
  1. Need advise how find problem in PID controller
    By phoenix_1 in forum Off Topic
    Last Post: - 28th October 2009, 02:22
  2. Replies: 5
    Last Post: - 12th December 2007, 17:47
  3. PIC programming algorithm - where is it to find?
    Last Post: - 24th June 2007, 19:31
  4. Another Help find something post
    By muddy0409 in forum General
    Last Post: - 12th January 2007, 19:38
  5. Can't find programmer
    By Russ Kincaid in forum mel PIC BASIC
    Last Post: - 1st February 2006, 18:49
