From datasheet:
The Timer0 module timer/counter has the following
features:
• 8-bit timer/counter
• Readable and writable
• 8-bit software programmable prescaler
• Internal or external clock select
• Interrupt-on-overflow from FFh to 00h
• Edge select for external clock
Hi, Savnik
Sayzer was only telling there's a 16 Bits timer in 16F88 : Timer 1 ...
but, if you want to use RA.4 and keep the same pinout ( must we understand PC board is already made ??? ) ... you'll have to turn to 18F1320 !
Or you could just count the Overflows from timer0 and make it a 16-bit or larger counter.
Savnik,
I understood that you already have a PCB and can not change it.
Then, if you are not using RB6, then just short it to RA4 manually with a tiny cable and use Timer1.
Hi, Savnik,
so, you want to use a ... 24 bits counter !!!
One more good reason to turn to 18F1320 AND use PBPL ... instead of PBPW !
But, once more ... will you tell us the PIC Osc frequency and the frequency range you intend to measure at PORTA.4
... as I smell something really interesting ...
And yet AGAIN!!!
PBP doesn't do fractional numbers by default!!!!! NEVER has, NEVER will!!!
You have to create your own method to extract any fractions you need.
Multiply the number your dealing with by 100, the 2 rightmost digits are your fraction....simple as that!
Or maybe not...
