TMR0 as counter
Results 1 to 24 of 24
Thread: TMR0 as counter
    Jun 2006
    Default TMR0 as counter
    I use TMR0 as counter to measure the frequency at RA4.
    How to get the decimal numbers.
    For 135,6 , i take only the 135 from TMR0.I want to take and the ,6 number.
    Jan 2006
    Istanbul
    Hi Savnik,
    Since TMR0 is 8-bit, there is no way you can get 135,6 as you like.
    You need to use TMR1 which is 16-bit.
    Then, you will read 135,6 at TMR1 register as 1356.
    Exclamation
    Hi, Sayzer
    As our friend Savnik didn't tell us which pic he uses ... it's difficult to answer.
    let's take the 18F252 i.e.
    Timer 0 can be 8 or 16 bits ... as you decide.
    Some more details from Savnik could be useful ... but we are used to !!!
    Jan 2006
    Istanbul
    Hi, Sayzer
    You are right Alain.
    That is my bad.
    But, I take 16F628A as the default PIC in my head when there is no mention of the PIC type.
    Soon enough I will change my default PIC to 18F2550.
    Jun 2006
    Thanks for yours answer.
    My default PIC is pic16f88.
    Maybe i change with pic18f1330 which have timer0 16bit.
    Question
    Hi, Savnik
    Also could eventually be useful :
    the PIC freq.
    The Porta.4 max input freq. to be measured
    Jan 2006
    Istanbul
    Quote Originally Posted by savnik View Post
    Savnik,
    16F88 already has 16-bit timer.
    Why change the whole car while you can change one tire and get going?
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
  3. 20 Digit Virtual LED Counter
    Last Post: - 19th November 2007, 05:02
  4. using TMR0 as a counter..
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 28th July 2007, 02:56
  5. Microcontroller with 2 way paging application problem
    Last Post: - 20th April 2007, 17:27
