Pic16F877 failure to assemble
Results 1 to 9 of 9
    Do you have MCS set up to us MPASM? Should not make a difference with you PIC though.
    The machine I tested your code on does not have MCS. I used MPLAB.
    What version of PIC BASIC PRO and MCS do you have?
    Jun 2008
    South Australia
    Post Pic16F877 failure to assemble
    I am only using MCS 3.0.0.5 as standalone , and PICBasicPro 2.45A. I do have Mplab V8.0 onboard but they no longer include the ability to compile from basic , and will only work with the *.asm file. If this programme compiles on your system , then it should compile on mine , unless I have a dodgy software loading.. I am about to remove PicBasicPro and MCS and reload them both.. I will post the results , most probably Monday....Thanks...Rod.
    This tells how to use PIC BASIC and MPLAB together.
    http://www.melabs.com/support/mplab.htm
    Works very well. I even use this on my Linux box.
    Jun 2008
    South Australia
    Talking Pic16F877 failure to assemble
    I am happy to announce that , after replacing the HDD in my desktop and reloading both MPLAB and PicBasicPro that I am up and running with my 16F877 compilations..anndd PBPro
    is running within MPLAB..
  1. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
  2. PIC16F877 I2C programme
    By cooqo in forum mel PIC BASIC
    Last Post: - 21st April 2008, 10:02
  3. Replies: 8
    Last Post: - 17th January 2007, 19:18
  4. button input PIC16F877
    By ob38 in forum mel PIC BASIC Pro
    Last Post: - 19th June 2006, 20:11
  5. Who's the Biggest Failure?
    By Squibcakes in forum Off Topic
    Last Post: - 1st November 2005, 15:37
