Making the Lab X1 communicate with the Lab X2
Results 1 to 13 of 13
    Jun 2008
    I say I am very new to programming because I have about three weeks into learning it, I was offered a job from my father to write the programs he uses in various applications, as such, I am trying to learn it as fast as humanly possible. I have done several sample projects pertaining to both interrupts and serial communication that where in the various books I have collected to learn PicBasic Pro, it's just serial communication and interrupts don't make much sense to me, from the information I have...Even after reviewing it several times. I think it's just a lack of understanding the concepts behind the two, which is why I am looking for more resources on them.
    Right now, whats hanging me up more than anything is the serial communications...I have had a hard time finding sample programs of two PICs interfaced with one another.
    Ideally I would like to find two sample codes for making Lab X boards talk to one another.
    Thank you,
    Matt
    Quote Originally Posted by MatthewM View Post
    A little bit of searching on these forums, right here, the PicBasicPro forums, the little search button at the top of the screen, blue background, white lettering, with a little downward facing arrow next to it, will get you a long way.
    You don't need an example of "2 Lab X boards talking to each" specifically, you only need an example where a PIC, any PIC, talks to another PIC, any PIC, thru some method.
    Jun 2008
    Thank you for the advice,
    Yes, I realize I don't need that specific of a program, it would just be ideal, since I could then easily implement it on my desk, and see the end results of how it worked.
    I am also searching through the forums, I was just curious if anyone knew of some off site resources as well, since searching Google has yielded me little or happened to know of something offhand that I may have missed in my searches, also, I figured I would put my situation out there in case there was a simple answer to it that I was just missing (I can't count how many times I have been hung up on something for hours, only to find the simplest, most obvious solution).
    Matt
    I am also searching through the forums, I was just curious if anyone knew of some off site resources as well.................
    Matt
    That's what I'm saying...there is a complete example of 2 PIC communication here...on this site...done by one of the most advanced members of this forum (no, not myself, obviously). I don't know what the thread is called, can't remember the title, but it's complete. And most likely you'll have to change it to match your PIC, your hardware, your needs.
    Jun 2008
    Oh, okay, thank you. I will attempt to find it immediately.
    Matt
    Matt
    http://www.picbasic.co.uk/forum/showthread.php?t=573
    Found it...right there in the 'Code Examples' section....half a page down...right there...
    Jun 2008
    Are you referring to the program she wrote for PC to PIC? Or is there another program in this thread for PIC2PIC?
    Matt
  1. Weird issue with Lab X1
    By Demon in forum General
    Last Post: - 25th March 2010, 05:30
  2. Newbie with LAB X1 timming problem
    By schlaray in forum mel PIC BASIC Pro
    Last Post: - 7th November 2006, 01:30
  3. code conversion
    By saturnX in forum mel PIC BASIC
    Last Post: - 3rd October 2005, 18:17
