a simple boxe timer (code included)
Results 1 to 25 of 25
    T.Jackson's Avatar
    T.Jackson Guest
    Default A Good Case
    The main reason "Select Case" is faster is because it allows you to structure your code. As with an IF statement there's still a "compare" operation being preformed, but it's usually far better optimized.
    The biggest problem with your original code is that every IF will be executed, which consequently wastes time.
    Say for example that b1 = 245, the first IF is tested, the result returns true because b1 is within range of (255 - 243), so the block of code associated with that IF is executed, timerN is set to 1 etc ...
    Now here's the problem -- all subsequent IFs are executed even though b1 is clearly out of range and the result will always return false while ever b = 245.
        If (b1 <= 255 And b1 >= 243) Then ' Comparison always performed
            timerN = 1
            timerAc = 600
            timerBc = 180
        End If
        If (b1 <= 242 And b1 >= 219) Then ' Comparison always performed
            timerN = 2
            timerAc = 180
            timerBc = 60
        End If
    Select Case can be configured in a way so that only one comparison is ever performed, only one block of code is ever executed.
    Trent Jackson
    Mar 2006
    INDIA
    Great,... Yes.
    IF AND THEN --- compile to 159 words.
    Select case --- compile to 58 words.
    I will have to compere all statements. eg. FOR/NEXT loops. while/Wend, GOTO, GOSUB/RETURN, HI/LOW, TOGGLE.
    For time of Execution speed and code space.
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by precision View Post
    while / wend (same as "do / loop" but without a condition) -- will always be faster than "for next loops" Main reason is because there is no counter, there's no constantly incrementing or decrementing after each iteration.
    But I encourage you to conduct your tests and post the results here.
    Trent Jackson
    T.Jackson's Avatar
    T.Jackson Guest
    Another thing also, the "AND" operator -- try to avoid it at all costs.
    if b1 = 100 then
       if b2 = 200 then
          Thank Mr Jackson for these invaluable tips
       end if
    end if
    is much better than ...
    if b1 = 100 and b2 = 200 then
      do something ...
    end if
    You might save a few bytes of code space, it'll run faster too.
    Can anyone tell me why?
    Trent Jackson
    IF you're actually asking a question vs. just talking out your.............................
    then...
    if b1 = 100 then
       if b2 = 200 then
       end if
    end if
    2 comparisons, 3 jumps
      do something ...
    end if
    3 'nested' comparisons (2 + 1), couple of extra 'state' bits to save in the middle of it all, plus 4 jumps
    IF you're posing a question for the class from the podium, then nevermind...
    Jun 2008
    here the 0.3 version.
    contains some bug fixes, the most important:
    in 0.2 timer values are contained in BYTE VAR, big values could not be showed (in 0.3 WORD type is used).
    regards,
    hOZONE
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 18:39
  2. Replies: 5
    Last Post: - 24th February 2009, 19:55
  3. Making Program Code Space your playground...
  4. Interrupt/timer not really interrupting...
    Last Post: - 22nd May 2005, 23:05
  5. Timer Accuracy
    By GEEZER in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 06:26
