How to set sequence of interrupt for PIC
Results 1 to 4 of 4
    May 2005
    Here is my code , Time/temp display and IR decode
    Pls advise ...
    Define LOADER_USED 1
    @ Device pic16F877A, xt_OSC, BOD_OFF, PWRT_ON, WDT_OFF, PROTECT_OFF 'WRT_On
    Segments Var PORTC
    Digits Var PORTD 'D
    i Var Byte
    n Var Byte
    Value Var Word
    ' Allocate variables
    command var Byte ' Storage for command
    J var Byte ' Storage for loop counter
    temp var Word ' Storage for temperature
    T VAR Word
    DQ var PORTD.5 ' Alias DS1820 data pin
    DQ_DIR var TRISD.5 ' Alias DS1820 data direction pin
    read_done var Byte
    '=================DS1307
    'include"modedefs.bas"
    'SO var portc.6 ' tx
    DPIN var PORTE.0 ' I2C DATA PIN 24LC256 and ds1307,with 4K7 pull up
    CPIN var PORTE.1 ' I2C CLOCK PIN with pulled up resister 4K7
    B1 var Byte
    B2 var Byte
    B3 var Byte
    B4 var Byte
    B5 var Byte
    B6 var Byte
    B7 var Byte
    B8 var Byte
    BB var Byte
    B_H var Byte
    B_L var Byte
    B_W VAR Word
    SEC VAR Byte
    M VAR Byte
    HR VAR Byte
    TIMES VAR Word
    LOOPP VAR Byte
    '==================DS1307
    'IR +++++++++++++++++++++
    pulses VAR Byte[16]
    BitMask VAR Word
    U VAR Byte 'loop index
    V VAR Byte 'byte index
    LeadIn VAR Word 'start pulse
    Lstatus con 10
    Bot con 15
    Cmd con 17
    Bot1 Var Byte
    Cmd1 var Byte
    Botx Var Byte
    Cmdx var Byte
    Botxstr Var Byte
    Cmdxstr var Byte
    n = 0
    '===========ir
    'TRISA = $F1 '1
    'PORTA = $FF
    TRISB = $01 '1
    PORTB = $01 '1
    TRISc = $00 ' Set segment pins to output
    portc = $FF
    TRISd = $F0 ' F0 Set digit pins to output
    portd = $FF 'FF
    TRISE = $00 ' Set digit pins to output
    portE = $FF 'FF
    On Interrupt GoTo IR_B0
    INTCON = %10010000 ' Enable RB0 interrupt
    ' Set time & date to 21:58:00 Tuesday 6th of July 2004
    ' [$00,$20,$21,$2,$6,$7,$4]
    ' sec,min,hrs,date,month,year
    ' I2CWRITE DPIN,CPIN,$D0,$00,[$00,$20,$21,$2,$6,$7,$4] ' Write to DS1307
    ADCON1 = 6 ' Set PORTA and PORTE to digital
    'debug ====
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_SPBRG 12 ' 19200 Bauds ,4 m
    'debug ====
    'pause 150
    mainloop:
    LOOPP = 0
    GoSub TEMP_PROCESS
    date:
    GoSub TIMEDS1307
    GoTo mainloop
    TEMP_PROCESS:
    GoSub init1820 ' Init the DS1820
    command = $cc ' Issue Skip ROM command
    GoSub write1820
    command = $44 ' Start temperature conversion
    GoSub write1820
    'Pause 2000 ' Wait 2 seconds for conversion to complete
    GoSub init1820 ' Do another init
    GoSub write1820
    command = $be ' Read the temperature
    GoSub write1820
    GoSub read1820
    'Display the decimal temperature
    value = ((temp>> 1)*100)+((TEMP.0*5)*10)
    GoSub display
    If LOOPP < 254 Then 'goto TIMEDS1307
    LOOPP = LOOPP + 1
    GoTo TEMP_PROCESS
    EndIf
    Return 'return to mainloop
    ' Initialize DS1820 and check for presence
    init1820:
    Low DQ ' Set the data pin low to init
    Pauseus 500 ' Wait > 480us
    DQ_DIR = 1 ' Release data pin (set to input for high)
    Pauseus 100 '100 ' Wait > 60us
    If DQ = 1 Then
    'Lcdout $fe, 1, "DS1820 not present"
    PORTC = $39
    Low DIGITS.0
    PAUSE 150
    PORTC = $0
    'Pause 150
    GoTo mainloop ' Try again
    EndIf
    Pauseus 400 ' Wait for end of presence pulse
    ' Write "command" byte to the DS1820
    write1820:
    For i = 1 To 8 ' 8 bits to a byte
    If command.0 = 0 Then
    GoSub write0 ' Write a 0 bit
    Else
    GoSub write1 ' Write a 1 bit
    EndIf
    command = command >> 1 ' Shift to next bit
    Next i
    ' Write a 0 bit to the DS1820
    write0:
    Low DQ
    Pauseus 60 ' Low for > 60us for 0
    ' Write a 1 bit to the DS1820
    write1:
    Low DQ ' Low for < 15us for 1
    @ nop ' Delay 1us at 4MHz
    Pauseus 60 ' Use up rest of time slot
    ' Read temperature from the DS1820
    read1820:
    For i = 1 To 16 ' 16 bits to a word
    temp = temp >> 1 ' Shift down bits
    GoSub readbit ' Get the bit to the top of temp
    Next i
    ' Read a bit from the DS1820
    readbit:
    temp.15 = 1 ' Preset read bit to 1
    Low DQ ' Start the time slot
    If DQ = 0 Then
    temp.15 = 0 ' Set bit to 0
    EndIf
    Pauseus 60 ' Wait out rest of time slot
    May 2005
    ' and next
    'READ TIME FROM DS1307
    TIMEDS1307:
    LOOPP=0
    loop:
    i2cread dpin,cpin,$d0,$00,[b1,b2,b3,b4,b5,b6,B7]
    'pause 10
    'BB=B1
    'gosub conv
    'SEC = ((B_H*10)+B_L)
    'serout SO,t9600,["sec ",#SEC,10]
    BB=B2
    GoSub conv
    M=(B_H*10)+ B_L
    'serout SO,t9600,["Min ",#M,10]
    BB=B3
    GoSub conv
    hR=(B_H*10)+ B_L
    'serout SO,t9600,["Hour ",#HR,":",#M,":",#SEC,10]
    value = ((HR*100) + m)
    'serout SO,t9600,["TIMES ",#VALUE,10]
    GoSub display_TIME
    If LOOPP > 254 Then loopp =0 :Return ' GOTO MAINLOOP
    LOOPP=LOOPP+1
    GoTo loop
    'RETURN mainloop
    conv:
    B_L=BB&%00001111
    B_H=BB&%11110000
    B_H=B_H>>4
    '================== 7 seg ment display ==============================
    display: 'Display Temp
    Disable Interrupt
    PORTC =$58 '$39 "C"
    Low DIGITS.0
    PAUSE 3 'INCREASE BRITE OF LED "C"
    'PAUSEUS 850
    'PORTC =$00 '$39 "C"
    'value = 125
    For i = 1 To 4 ' Loop through 4 digits
    n = Value Dig i ' Get digit to display
    ' Gosub display1 ' Display the value
    Digits = $ff
    LookUp n, [$3F, $06, $5B, $4F, $66, $6D, $7D, $07, $7F, $6F,_
    $77, $7C, $39, $5E, $79, $71, $0FF], Segments
    If i = 2 Then segments = segments + 128 'Digit 2 show dot
    Digits = ~DCD i
    PAUSE 1 'INCREASE BRITE OF LED "number"
    Next i
    Enable Interrupt
    display_TIME: 'Display time
    Disable Interrupt
    dot var Byte
    For i = 0 To 4 ' Loop through 4 digits
    Digits = $ff
    If dot < 100 Then
    Digits = ~DCD i
    dot = dot+1
    Else
    dot = dot+1
    If dot < 254 Then
    Digits = ~DCD i
    Else
    dot = 0
    digits = ~DCD i
    EndIf
    EndIf
    Next i
    Enable Interrupt
    '+++++++ir decode +++++++++++++++++++++++++
    Showoutput:
    'HSEROUT ["Bot ",dec bitmask.LOWBYTE,13,10]
    'HSEROUT ["Cmd ",dec bITMASK.highbyte,13,10]
    'botx = bitmask.lowbyte
    'Cmdx = bitmask.highbyte
    Disable Interrupt
    If bitmask.LowByte = 164 Then ' 36 BOTTM 9
    If bitmask.HighByte = 64 Then ' 32
    Toggle PORTB.7 'RELAY B.1
    EndIf
    EndIf
    If bitmask.LowByte = 36 Then ' 36 BOTTM 9
    If bitmask.HighByte = 32 Then ' 32
    Toggle PORTB.6 'RELAY B.1
    EndIf
    EndIf
    If bitmask.LowByte = 168 Then ' 36 BOTTM 9
    Toggle PORTB.5 'RELAY B.1
    EndIf
    EndIf
    BITMASK =0
    'enable interrupt
    GoTo ActiveINT_B0
    '============IR decode =======================
    Disable
    IR_B0:
    PulsIn PORTB.0, 0, LeadIn
    'Sumsung and Hitachi check
    AB:
    If LeadIn < 400 Then GoTo ActiveINT_B0 '885 hitachi, sumsung 400
    If LeadIn > 1045 Then GoTo ActiveINT_B0
    For U = 0 To 15
    PulsIn PORTB.0, 1, pulses[U]
    Next U
    For U = 0 To 15
    Next U
    For U = 0 To 11
    If (pulses[U] < 40) Or (pulses[U] > 300) Then
    GoTo ActiveINT_B0
    EndIf
    If pulses[U] > 99 Then
    BITMASK.0 = 1
    BITMASK = BITMASK << 1
    EndIf
    BITMASK.0 = 0
    Next U
    GoTo Showoutput
    ActiveINT_B0: 'active interrupt b0
    PULSES = 0
    INTCON.1 = 0
    value =0
    Resume
    Enable Interrupt
  1. Pin won't stay high during Repeat...Until loop??
    Last Post: - 17th August 2009, 00:57
  2. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  3. Can't ID interrupt source with this IntHandler??
  4. Interruptus Frustratus
    Last Post: - 17th April 2009, 21:36
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
