18F8722 sample code
Results 1 to 9 of 9
    New Zealand
    Yah, I know the upgrade is only $25, and if needs be I'll end up getting it. I only use PBP from time to time, if it were a full time effort then I'd deff upgrade when new releases come out. However have found if I change lines like:
    __CONFIG _CONFIG1H, _OSCS_OFF_1H & _XT_OSC_1H
    in my INC files to
    As it was sortof telling me in the errors then those particular errors disappear which is good - however these errors are now superceeded by others which is not so good.
    Error[176] : CONFIG Directive error: (missing "=" in parameter "_CONFIG1H")
    So I suppose I've been making progress but I've now tried to place a = sign in the config1h line copying the inc file from MPASM but no joy - any ideas?
    Yep, read:
    http://www.picbasic.co.uk/forum/show...=preset+config
    It's got all the good info in it for doing up the config fuses.
    New Zealand
    Thanks, I was reading through that. Still can't make anything work tho, the whole missing "=" thing has got me confused. I've tried replacing statements like _OSC_HS_1H with ones like OSC = XT which are found in the INC file of MPASM but still it keeps saying "=" is missing (config directive error)
    Anyone have any ideas on how to rewrite these? (just one will do I'm sure I could figure the rest if given an example)
    CONFIG _CONFIG2L, _BOR_ON_2L & _BORV_20_2L & _PWRT_ON_2L
    CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
    CONFIG _CONFIG3H, _CCP2MX_ON_3H
    CONFIG _CONFIG4L, _STVR_ON_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
  1. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. MN1307 sample code problem
    Last Post: - 20th November 2008, 21:41
  5. Making Program Code Space your playground...
