one wire
Results 1 to 8 of 8
Thread: one wire
    IF I make the mclr pin an input will the pic still program ok If i just oplug it into a programmer? I wont disable it's ability to be programmed if all pins are designated inputs or outputs?
    The only thing to watch out for is the high voltage (13 v or so) on MCLR during programing. Some sort of isolation is all that is needed . Anything from a diode to a switch. Remember, MCLR pin can only be an INPUT.
    You have the PICKIT2 docs? There are isolation drawings there and I think on the PBP web site.
    Post
    Hi, Karen
    1) Go here :
    http://www.maxim-ic.com/products/ibu...tmex/index.cfm
    download the soft corresp. to you system ...
    2) Download the dS2480 Datasheet ... and get one or two of them ( think to the SAMPLES !!! )
    3) Give me a PM mail where I can send you the Scheme, PCB and parts placement.
    OR
    Build THAT ...
    http://www.elektor.de/jahrgang/2008/...e.497315.lynkx
    You'll be able to read the Device IDs ...
    OR
    Just read your Datasheet ...
    READ ROM [33h]
    This command can only be used when there is one slave on the bus. It allows the bus master to read the
    slave’s 64-bit ROM code without using the Search ROM procedure. If this command is used when there
    is more than one slave present on the bus, a data collision will occur when all the slaves attempt to
    respond at the same time.
    64-BIT LASERED ROM CODE
    Each DS18B20 contains a unique 64–bit code (see Figure 6) stored in ROM. The least significant 8 bits
    of the ROM code contain the DS18B20’s 1-Wire family code: 28h. The next 48 bits contain a unique
    serial number. The most significant 8 bits contain a cyclic redundancy check (CRC) byte that is
    calculated from the first 56 bits of the ROM code. A detailed explanation of the CRC bits is provided in
    the CRC GENERATION section. The 64-bit ROM code and associated ROM function control logic allow
    the DS18B20 to operate as a 1-Wire device using the protocol detailed in the 1-WIRE BUS SYSTEM
    section of this datasheet.
    64-BIT LASERED ROM CODE Figure 6
    8-BIT CRC 48-BIT SERIAL NUMBER 8-BIT FAMILY CODE (28h)
    MSB LSB MSB LSB MSB LSB
    and buid a little application just to read the ID ...
    Something more ???
    Mar 2008
    Totally perfect thanks
    not sure if I'll buy the usb adaptor or just make the interface yet but really good info and exactly what I was looking for
    I would just make an interface but it's going to take a few weeks for samples or orders to get from US to UK so might be easier just to buy the usb one made up
    especially as they are srface mount devices and I cant guarantee my hand or eyes are good enough to work with them
  1. 1 Wire Search Routine
    By Dave in forum Code Examples
    Last Post: - 4th March 2016, 07:39
  2. Need Single wire serial LCD converter example
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 02:30
  3. how can I make 1 wire between two pic 16f877
    By povulon in forum mel PIC BASIC Pro
    Last Post: - 30th July 2008, 14:44
  4. Oscillator stops when touching with a wire
    By Wilbert Ingels in forum mel PIC BASIC Pro
    Last Post: - 25th April 2008, 08:51
  5. RPM with wire and PIC
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 14th December 2004, 20:42
