one wire
Results 1 to 8 of 8
Thread: one wire
    Mar 2008
    Default one wire
    Has anyone any suggestions on how to read the id code from 1wire products?
    I've read up on the 1wire project on Rentron.com and have a slight problem
    the code below assumes you have a serial 4 X 20 LCD
    HOW would I modify this to work with a normal parallel 4 X 20 lcd module as I havent figured out how to convert it to serial yet, and it would be great if this code could be made work on a "normal" lcd module, or someone can give me ideas on it please?
    What I eventually want to do is have 2 ds18b20's and actually use the 1wire properly instead of having them on seperate ports!
    '*  Name    : 1-Wire-ID.Bas                                     *
    '*  Author  : Bruce Reynolds                                    *
    '*  Date    : 11/10/2001                                        *
    '*  Notes   : 1-Wire Identifier                                 *
    '*          ; Identifies & Prints 1-Wire Device Information     *
    '*          : Uses 20 x 4 Serial LCD for Display                *
    DEFINE  LOADER_USED 1   ' Boot loader is being used
    DEFINE  DEBUG_MODE  1   ' Send Inverted serial data with debug
    DEFINE  DEBUG_REG PortB ' Debug Port = PortB
    DEFINE  DEBUG_BIT 0     ' Debug.bit = PortB.0
    DEFINE  DEBUG_BAUD 9600 ' Default baud rate = 9600
    DEFINE  OSC 4           ' We're using a 4 MHz oscillator
    DQ      VAR PortC.0	' One-wire data pin "DQ" on PortC.0
    Clr     CON 1           ' Serial LCD command to clear LCD
    LINE1   CON 128         ' Line #1 of serial LCD
    LINE2   CON 192         ' Line #2 of serial LCD
    LINE3   CON 148         ' Line #3 of serial LCD
    LINE4   CON 212         ' Line #4 of serial LCD
    Ins     CON 254         ' Instruction for LCD command-mode
    ID      VAR BYTE[8]     ' Array storage variable for 64-bit ROM code
    Begin:
        PAUSE 500           ' Wait .5 second
        DEBUG Ins,Clr       ' Clear LCD on power-up
    Start_Convert
        OWOUT DQ, 1, [$33]  ' Issue Read ROM command
    ID_Loop:
        OWIN DQ, 0, [STR ID\8]' Read 64-bit device data into the 8-byte array "ID"
        DEBUG Ins,Line1,"Family Code = ",HEX2 ID[0],"h"
        DEBUG Ins,Line2,"Ser# = ",HEX2 ID[1],HEX2 ID[2],HEX2 ID[3],HEX2 ID[4],HEX2 ID[5],HEX2 ID[6],"h"
        DEBUG Ins,Line3,"CRC Value = ",HEX2 ID[7],"h"
    ID_Device:
        IF ID[0] = $5 THEN
           DEBUG Ins, Line4, "Device = Switch     "
        IF (ID[0] = $28) OR (ID[0] = $22) THEN
           DEBUG Ins,Line4, "Device = Temp Sensor"
        IF ID[0] = $01 THEN
           DEBUG Ins,Line4, "Device = Serial #   "
        PAUSE 10000         ' 10-second pause
        GOTO Start_Convert
    OR I noticed in his description he said...
    The code is easy to convert to any PIC, and the serial LCD can easily be replaced by using any RS-232 terminal program.
    Can anyone give me any ideas on doing this? as it would be a lot simpler to have a small board to plug the individual ds18b20's (or any other 1wire device) in and just read the 64-bit ROM number from each one and display on the pc, saves wasting an lcd module! I presume I'd just have to have a small board with a 5v regulator and that should be able to be powered from the com port? any clues as to how to communicate with the 1wire device or what program/commands?
    This is from the PBP manual
    Command Operation
    $FE, 1 Clear display
    $FE, 2 Return home
    $FE, $0C Cursor off
    $FE, $0E Underline cursor on
    $FE, $0F Blinking cursor on
    $FE, $10 Move cursor left one position
    $FE, $14 Move cursor right one position
    $FE, $80 Move cursor to beginning of first line
    $FE, $C0 Move cursor to beginning of second line
    $FE, $94 Move cursor to beginning of third line
    $FE, $D4 Move cursor to beginning of fourth line
    $FE is the same as Ins CON 254
    Make sure you have the DEFINES like the manual has with the exception of
    ‘ Set number of lines on LCD
    DEFINE LCD_LINES 2
    Change to 4
    And follow the schematic, POT and all (several seem to not use the pot and wonder why it will not work, some LCDs will not require it, but when in doubt...)
    Mar 2008
    Thanks, that actually helped a LOT, even though it threw me at first and I had to read it several times...
    IF I've got what your saying right, the code to use a standard 4 line lcd module becomes this?
    '*  Author  : Bruce Reynolds, modified by Me!                   *
    '*  Date    : 18/16/2008                                        *
    '*  Version : 1.1                                               *
    '*          : Uses 20 x 4 PARELLEL LCD for Display              *
    Begin:
        lcdout $fe, 1       ' Clear LCD on power-up
    Start_Convert
    ID_Loop:
        lcdout $FE, $80 "Family Code = ",HEX2 ID[0],"h"
        lcdout $FE, $C0"Ser# = ",HEX2 ID[1],HEX2 ID[2],HEX2 ID[3],HEX2 ID[4],HEX2 ID[5],HEX2 ID[6],"h"
        lcdout $FE, $94  "CRC Value = ",HEX2 ID[7],"h"
    ID_Device:
        IF ID[0] = $5 THEN
           lcdout $FE, $D4, "Device = Switch     "
           lcdout $FE, $D4 "Device = Temp Sensor"
        IF ID[0] = $01 THEN
           lcdout $FE, $D4 "Device = Serial #   "
        GOTO Start_Convert
    POT??? Didn't actually see a schematic. I'm assuming you mean the pot to vary the contrast of the lcd?
    Oh sorry 2 other things
    I assume this can be used with most small pic's ?
    2nd one
    Using a DS2405 switch, am I right in thinking that once I've sent a command to either turn it on or off then it stays latched in that state untill it's addressed again and told to do something else?
    Just seen another problem.
    OWOUT DQ, 1, [$55,$05,$C5,$C3,$08,$00,$00,$00,$CD]' Match ROM, byte-sized, reset before
    I understand the $55 is Match rom BUT it says
    The red hexadecimal number $55 is the command for Match ROM.
    The blue hexadecimal numbers $05,$C5,$C3,$08,$00,$00,$00,$CD
    are the unique 64-bit ROM code numbers inside the specific DS2405
    addressable 1-wire switch we're trying to communicate with.
    The problem I have is the hex code for the device
    Using his device ID routine (above) it comes back with an example but only shows 6 sets of 2digit Hex numbers but above addressing the 1wire units, it shows the address as 8 sets of 2 digits
    UNLESS? in his example aboe the $05 is the family code, and the $CD at the end is the CRC code??
    So any device I want to address I'd put the Family code first then the 64bit address then finish it with the CRC code?
    The LCD code looks OK. Have you tried it yet? Yes, it will work with any PIC with enough pins.
    The drawing is at the end of the LCD section in the PBP manual.
    I will have to leave the one wire stuff for someone else. Sorry
    Mar 2008
    Thats fine thanks
    Actually I've only skipped through the manual to bits I really need to research that I cant find answers elsewhere, but I found the easiest and best way to learn was study other bits of code and try and figure out whats going on, then modify it to do what I want, adding other bits as I need.
    Probably the wrong way but it works for me, although i might annoy some people with so many questions!
    No havent tried it yet, I'm trying to work out the whole code before I build the project then I can just program it and try the various sections in "situ" although I will have to build a small board just to get the rom address of the 1wire devices I have!
    Although I might make it a bit more interesting by adding a header or an ICD2 or Pickit2 and a zif socket then I can use the board to get the addresses, AND program the pics
    OH anyone know the answer to this?
    IF I make the mclr pin an input will the pic still program ok If i just oplug it into a programmer? I wont disable it's ability to be programmed if all pins are designated inputs or outputs?
    The only thing to watch out for is the high voltage (13 v or so) on MCLR during programing. Some sort of isolation is all that is needed . Anything from a diode to a switch. Remember, MCLR pin can only be an INPUT.
    You have the PICKIT2 docs? There are isolation drawings there and I think on the PBP web site.
  1. 1 Wire Search Routine
    By Dave in forum Code Examples
    Last Post: - 4th March 2016, 08:39
  2. Need Single wire serial LCD converter example
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 03:30
  3. how can I make 1 wire between two pic 16f877
    By povulon in forum mel PIC BASIC Pro
    Last Post: - 30th July 2008, 15:44
  4. Oscillator stops when touching with a wire
    By Wilbert Ingels in forum mel PIC BASIC Pro
    Last Post: - 25th April 2008, 09:51
  5. RPM with wire and PIC
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 14th December 2004, 21:42
