LED Machine Tach For Tired Eyes
Results 1 to 34 of 34
    Quote Originally Posted by danielhr77 View Post
    First, I would like to say thanks to Sam for sending me the code and the schematic.
    Second, I have a question: what is the maximum RPM this circuit/code can read?
    Thanks!
    Daniel.
    Hi Daniel,
    I added this line:
    if displays > 9999 then displays = 9999
    to keep the display from rolling over 9999. What use do you have for this tach? I do not think I would try it on a turbine, as it updates too slowly, but it was written for a lathe. It will go over 9999 without that line, the max is unexplored. Perhaps someone who is skilled at math could tell you. The displays can be cascaded, if you feel adventurous.
    I have a few brushless R/C trucks, they have an optic sensor on the transmission and I would like to read the RPM. They go up to 50.000 RPM! I'll give it a try.
    Cool, keep us posted, I am curious as to the limits of count. I am thinking the variable might overflow if RPM goes too high, and you might have to alter the sampling rate or use some form of prescaler.
    Dec 2008
    Ploiesti, ROMANIA
    I try to use code from post #1 to my thermometer with 16F628A, DS18B20 and LED display ( like in : http://melabs.com/resources/articles/ledart.htm fig.6). To another topic, I receive one working code, from one user (thanks !).
    But, I am still disappointed, because MY code don't work. Please, what's wrong with him ? Thank you !
    @ DEVICE pic16F628A, intOSC_osc_noclkout, WDT_OFF, PWRT_ON, MCLR_OFF, LVP_OFF, CPD_OFF, PROTECT_OFF
    TRISA= %11110000                   ' RA0..3=Outputs RA4=Input
    TRISB= %00000000 			             ' RB0..RB7=Outputs
    CMCON=7                            ' Disable comparators
        DQ          VAR PORTA.4
        DS18B20_12bit 	CON %01111111           ' 750ms,   0.0625°C
        I           VAR BYTE
        SIGN        VAR BIT
        TEMPERATURE     VAR WORD ; TEMPERATURE REGISTER
        n			var byte
    segments 		var portb
    digits		    var porta
    value			var word
    MAINloop :
            OWOUT DQ ,1,[$CC,$44]
    WaitLoop:
    While not DQ
    Wend
            OWOUT DQ ,1,[$CC,$BE]
            OWIN  DQ ,2,[TEMPERATURE.LOWBYTE , TEMPERATURE.HIGHBYTE]
            IF TEMPERATURE.15 = 1 THEN
                TEMPERATURE = (65535 - TEMPERATURE) + 1
                SIGN = 1
                SIGN = 0
            value = (TEMPERATURE * 10)/16
            gosub display
    goto mainloop
    ' Subroutine to send the number (0 - 9999) in Value to LEDs
    display:
    	For i = 0 To 3		' Loop through 4 digits
    		n = value Dig i	  ' Get digit to display
    		GoSub display1	' Display the digit
    				      ' Leave it on 2 millisecondS
    	Next i			      ' Do next digit
    ' Surboutine to display one digit on LED
    '  i = digit number
    '  n = number to display
    display1:
    	'Digits = $ff		' All digits off to prevent ghosting
    	' Convert binary number in n to segments for LED
    	Lookup n, [$40, $79, $24, $30, $19, $12, $02, $78, $00, $18,$7f], Segments
      ' logic low complements
    	' Set digit pin i to 0 (on) and the rest of the pins to 1 (off)
    	Digits = ~Dcd i
      Pause 1 'Increase to make digits brighter and flicker worse
    Unhappy
    Hi, Fratello
    One thing is obvious ...
    The " Waitloop " , for sure, can't be used whith multiplexed LED's ...
    One thing is surprising ...
    Do you think your temp calculation is compatible with the provided Led Display ???
    One thing is really hazardous ...
    While dealing with the display ... you write over your PortA inputs as well as outputs !
    Dec 2008
    Ploiesti, ROMANIA
    Default Mea culpa...
    One, two, three things are for sure : I am a sucker !
    It's not the first time when "the language barrier" make me problem...I'm really sorry if I borried somebody .
    In the link that I posted it's the schematic (with reference to PBP code) I tried to make...It's sure that I must careful read (and understand !). Thank You verry much for attention and reply ! All the best !
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. LCD will not start
  5. LED Tach Sources?
    By Netjammer in forum mel PIC BASIC Pro
    Last Post: - 17th October 2004, 04:47
