LED Machine Tach For Tired Eyes
Results 1 to 34 of 34
    Mar 2004
    Hi Joe,
    I must be doing something wrong. I mounted the magnet to the spindle of my mill which on high should be spinning about 2400 rpm. The display is reading anywhere from 250 to 1010 and constantly fluctuating. This is with displays=displays*10. When programmed with displays=displays*60 it's varying from 3000 to over 5000 and again, constantly fluctuating.
    I'm using a 10mhz xtal and have the code set at 10mhz OSC too. Could this be causing a problem ? I'm trying to figure it all out on my own but I'm not getting it, "obviously".
    Try putting a resistor from the input to ground, it sounds like it is picking up stray signals (rf?) and twist the input wires or shield them. I would try say 10K first. The displays=displays*10 would only be valid with 6 magnets.
    Mar 2004
    Default Update
    Hey Joe,
    I've been real busy with other things and meant to update this sooner.
    The tach is working just fine, I have milled the PCB and installed one in my SC machine and it's great. I did switch to shielded wire and had to use a 1K resistor (I already had a 10K in place and that didn't work) and a .01 uf to ground.
    When I get some more time I'm going to order two more of the 4 digit displays from Sure Electronics and add them to my lathe and CNC mill.
    So again, I really appreciate you providing the code (I've learned from it too) and your help.
    I'll post a pic of the tach in operation later. Also, if anyone would like the schematic and PCB layout from Eagle I'll provide that.
    Best regards
    Quote Originally Posted by Sam View Post
    Hey Joe,
    Best regards
    Hi Sam,
    I appreciate the feedback! Thanks!
    Mar 2004
    Here it is in operation ! It's doing a fine job, very happy with it.
    Also a pic of the pickup coil embedded in epoxy inside a plastic tube, the magnet is epoxied to the shaft.
    First, I would like to say thanks to Sam for sending me the code and the schematic.
    Second, I have a question: what is the maximum RPM this circuit/code can read?
    Thanks!
    Daniel.
    Quote Originally Posted by danielhr77 View Post
    Thanks!
    Daniel.
    Hi Daniel,
    I added this line:
    if displays > 9999 then displays = 9999
    to keep the display from rolling over 9999. What use do you have for this tach? I do not think I would try it on a turbine, as it updates too slowly, but it was written for a lathe. It will go over 9999 without that line, the max is unexplored. Perhaps someone who is skilled at math could tell you. The displays can be cascaded, if you feel adventurous.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. LCD will not start
  5. LED Tach Sources?
    By Netjammer in forum mel PIC BASIC Pro
    Last Post: - 17th October 2004, 04:47
