LED Machine Tach For Tired Eyes
Results 1 to 34 of 34
    Mar 2004
    Quote Originally Posted by jderson View Post
    Hi Sam-
    I have been using the AFL series parts from NVE (DigiKey). They work good, but kind of expensive ($9 U.S.) The datasheet says bandwidth is 100khz., but I have only run them at several hundred R.P.M.
    Thanks jderson, I'll take a look at those. I'm also considering trying IR emitter/detector with a reflective stripe. But would prefer the hall sensor method.
    Thanks again,
    Sam
    Quote Originally Posted by Sam View Post
    Thanks again,
    Sam
    So many ways Sam, Hall effect, plain old coil and magnet glued on the shaft **, spinning disk with holes and opto, old relucter and pickup from car distributor, heck even points for low rpm application, all can be directly driven or run off an idler belt / pulley setup, who cares how many sensor triggers per revolution, you can tweak it in the software to do any math required. On my lathe I plan to put a small belt to the "encoder" from the headstock so I do not have to hassle modifying the spindle. Oh I thought of another one, if your spinning shaft has a nut spinning too aim a small magnet at the nut and a coil of wire at it at about a 60degree angle, might work as a reluctor. Or a spinning gear . . .
    ** Note: Remember those aftermarket Cruise Control units from the 1980s?
    Yup, we used to install some magnet on the drive shaft when there was no existing VSS source. been a long long time
    Mar 2004
    Joe, thanks for all the ideas. I chose to go with the coil and magnet. I did this for several reasons, mainly I didn't want to wait for a new hall effect module to come in.
    I used the coil from a 24v relay I had, I left the bar in the center of course. I got a small but quite strong round magnet from the earpiece of an old cell phone. I connected the coil to a NPN transistor which I forward biased to increase the sensitivity and then ran the output of that NPN into a PNP to give a good positive pulse to the 16F628A.
    As a test while everything was still breadboarded, I put a cardboard disc about 6" in dia. on a variable speed drill, taped the magnet to the edge of the disc a gave it a spin. The readout appears to work perfectly, varying with the speed of the drill very reliably ! And the magnet will still work when it's about 1" away. I will have it setup so that the coil and magnet are in close proximity though.
    Now I'm going to do the board design in Eagle, then use PCBGcode and mill several boards out on my CNC mill and I should be set.
    I'm real happy about this and again, I really appreciate the code and all the help !
    Best regards,
    Sam
    EDIT: I forgot to mention that it displays only in multiples of 60. ie: 60,120,180,240, etc. RPM. Not "linear", I left the formula as displays=(displays*60) as that's all I need for the way I'll have it attached to the first machine I use it on.
    I never noticed that, I will look into it.
    EDIT: Ok I think it is Displays = Displays * 60 If you use 6 magnets and make this statement Displays = (displays * 10) you will get 10 RPM resolution. I plan to use a multiple pulse per revolution encoder scheme which will significantly increase resolution. I think I will build it using parts from an automotive distributor (the guts) and fabricate all of the rest.
    Mar 2004
    Hi Joe,
    I must be doing something wrong. I mounted the magnet to the spindle of my mill which on high should be spinning about 2400 rpm. The display is reading anywhere from 250 to 1010 and constantly fluctuating. This is with displays=displays*10. When programmed with displays=displays*60 it's varying from 3000 to over 5000 and again, constantly fluctuating.
    I'm using a 10mhz xtal and have the code set at 10mhz OSC too. Could this be causing a problem ? I'm trying to figure it all out on my own but I'm not getting it, "obviously".
    Try putting a resistor from the input to ground, it sounds like it is picking up stray signals (rf?) and twist the input wires or shield them. I would try say 10K first. The displays=displays*10 would only be valid with 6 magnets.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. LCD will not start
  5. LED Tach Sources?
    By Netjammer in forum mel PIC BASIC Pro
    Last Post: - 17th October 2004, 04:47
