LED Machine Tach For Tired Eyes
Results 1 to 34 of 34
    Threads left open are useless to others, so I will post what I came up with.
    @MyConfig = _HS_OSC  & _LVP_OFF & _WDT_OFF & _CP_OFF
    @MyConfig = MyConfig & _BODEN_OFF & _MCLRE_ON & _PWRTE_ON
    @ __CONFIG   MyConfig
    '===================== Set Defines ===================================
    DEFINE OSC 20
    '==================== Set up registers ===============================
    INCLUDE "MODEDEFS.BAS"
    CMCON  = 7          ' Shut off comparators
    TRISA  = %00010000  ' Set PORTA to all outputs A.4
    TRISB  = %00000000  ' Set PORTB Outputs
    PortA = $20         ' Set all Port A outputs low
    PORTB = 0           ' Set all Port B outputs low
    '=====================Set Constants ================================
    'no constants as yet
    '===================== Alias Ports =================================
    TacInput var PORTA.4 ' Input pin for T0CKI -  Tach In
    SDO      VAR PortB.0              ' 7 Segment Data  Out
    SCLK     var PortB.1              ' 7 Segment Clock Out
    DLE      var portB.2              ' 7 Segment Latch Enable
    '===================== Declare Variables =============================
    Digit_1          var byte    ' Thousands digit
    Digit_2          var byte    ' Hundreds  digit
    Digit_3          var byte    ' Tens      digit
    Digit_4          var byte    ' Units     digit
    DIGIT_OUTPUT     VAR BYTE    ' Storage for each digit before lookup
    CounterTotal     var word    ' Someplace to count input pulses
    Displays         VAR WORD    ' Storage while Countertotal gets cleared
    '===================== Zero Digits ====================================
    Digit_1 = 0
    Digit_2 = 0
    Digit_3 = 0
    Digit_4 = 0
    '===================== EEPROM DATA ===================================
    DATA @ 0,126,48,109,121,51,91,95,112,127,123   'DIGITS WITHOUT DECIMAL
    ;DATA @ 10,254,176,237,249,179,219,223,240,255,243 'DIGITS WITH DECIMAL
    '=========================== Main Loop ==============================
    LOOP:
    COUNT PortA.4,1000,CounterTotal
    DISPLAYS=0
    DISPLAYS=(DISPLAYS+CounterTotal) ' load OverflowTotal into displays
    displays=(displays*60) ' change this formula to agree with encoder
                           ' Formula is for 1 PPR, 30 for 2 PPR, 15 for 4 PPR
                           ' 10 for 6 PPM, ET-AL, OR TURN THEM AROUND 2 FOR 30
                           ' 3 for 20,4 for 15,5 for 12, 6 for 10
    gosub Display
    CounterTotal=0
    GOTO LOOP
    '=========================== Subroutines ============================
    Display:
    DIGIT_OUTPUT = DISPLAYS dig 0 ' Load Thousands Digit
    READ DIGIT_OUTPUT, DIGIT_1    ' Convert and Load Thousands Variable
    DIGIT_OUTPUT = DISPLAYS DIG 1 ' Load Hundreds  Digit
    READ DIGIT_OUTPUT, DIGIT_2    ' Convert and Load Hundreds Variable
    DIGIT_OUTPUT = DISPLAYS DIG 2 ' Load Tens of Units Digit
    READ DIGIT_OUTPUT, DIGIT_3    ' Convert and Load Tens  Variable
    DIGIT_OUTPUT = DISPLAYS dig 3 ' Load Ones of Units Digit
    READ DIGIT_OUTPUT, DIGIT_4    ' Convert and Load Units Variable
    shiftout SDO,SCLK,4,[DIGIT_1\8,DIGIT_2\8,DIGIT_3\8,DIGIT_4\8]
    pulsout DLE, 500
    pause 125
    This Works on the bench , I have yet to try it on the machine as I am still making parts for it.
    A second more complicated unit using a bargraph in addition to numbers is posted in attachment below:
    Question
    Hi, Joe
    from your program ... may I think you use "something like" a MAX 7219 Serial LedDriver ???
    Hi, Joe
    Hi Alain,
    I used this: http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=022
    and this
    http://cgi.ebay.com/40-segment-2-54m...d=p3911.c0.m14
    The price was right.
    Default New data
    Hi everyone,
    Forum member SAM brought to my attention this code wasn't doing as expected
    with the sepecified display. When I first set this up, the display I used did not
    agree with the printed data in the data sheet, the new display they are selling does.
    Replace the eeprom data in the listed code with the following:
    data @ 0,252,96,218,242,102,182,62,224,254,230
    Update, the Chinese vendor which supplies this display is : http://www.sureelectronics.net/
    My Thanks to SAM for bringing this to my attention.
    JS
    Seems they have pretty nice stuff there, probably not suitable for mass production, but interesting and cheap.
    Mar 2004
    Well the code provided by Joe works great now. I really appreciate Joe posting this and then taking the time to help me get it working. I have three machines that I really need tach's on, a spincaster, a cnc mill, and a lathe and this display and Joe's code fits the application perfectly.
    The display I got from Sure Electronics was this one. It was only $14.00 delivered and is quite bright.
    I'm in the process of setting up a hall effect sensor as the pickup and it should work fine for this.
    Thanks again Joe,
    Sam
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. LCD will not start
  5. LED Tach Sources?
    By Netjammer in forum mel PIC BASIC Pro
    Last Post: - 17th October 2004, 04:47
