PULSOUT versus toggling a pin
Results 1 to 10 of 10
    Omaha, Nebraska USA
    Question PULSOUT versus toggling a pin
    I need to send a 5 us pulse to a pin. I'm using a 16F88 at 8 MHz and need to keep processing overhead down.
    Which is faster, using PULSOUT or this:
    PIN=1
    PAUSEUS 5
    PIN=0
    I have to do this at different (and varying) times on 5 different pins.
    Russ
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    At 8mHz, the minimum PAUSEUS is 12uS (14-bit cores).
    Minimum PULSOUT is 5uS.
    Apples and Oranges (no tomatoes)
    Although, here's an ASM delay routine that can do down to 1uS at 8mHz.
    http://www.picbasic.co.uk/forum/show...8&postcount=22
    Then just ...
    PIN=1
    @  DelayUS 5
    PIN=0
    It only works with constants though, no variables.
    hth,
    Here's a simple macro I use for short delays.
    asm
    DelayCycles macro ncy ; ncy can be from 1 up to 256
      local n
    n set   (ncy)   ; assign ncy value to label n
      while n > 2   ; inserts goto $+1 while n > 2
        goto $+1    ; burn 2 cycles
    n   set   n - 2 ; n = n - 2
      endw
                    ; handle left-overs
      while n > 0   ; 1 nop for odd numbers
        nop         ; burn 1 cycle
    n   set   n - 1 ; n = n - 1
      endw
    endasm
      HIGH 0
      @ DelayCycles 1  ; adds 1 nop
      LOW 0
      @ DelayCycles 5  ; adds 2 x goto $+1 and 1 x nop
      GOTO Main
    It provides delays from a single instruction cycle up to 256. For a 5uS delay at 8MHz just
    use @ DelayCycles 10
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Hello
    Here a simple way to do a fast pulse out delay. At 8mhz setting portb =1 takes 2 cycles or 1us.
    Portb.1 =1
    Portb.1 =1
    Portb.1 =1
    Portb.1 =1
    Portb.1 =1
    Portb.1 =0
    Omaha, Nebraska USA
    Oh, <i>DUH!</i> I <u>did</u> know about that minimum; I can't believe I forgot it!
    Interestingly, if you give PAUSEUS anything less than 12 (at 8 MHz), it defaults to 12. I verified this on the scope.
    Also from looking at the scope: Using PULSOUT takes longer despite allowing the shorter pulse length.
    Mark, thanks for the idea. Ideally, I'd like to have a 3 us, so I'll play with your suggestion and see how it looks.
    Russ
    Sep 2007
    USA, CA
    While Mark's way is functional, I prefer other methods to avoid thinking the repetitive PortB.1=1 isn't a typo or accidental copy/paste.
    There are two more ways to do it. Using NOP's makes it very clear that it is a delay.
    PortB.1=1
    asm
    NOP
    NOP
    NOP 'repeat as necessary
    endasm
    PortB.1 = 0
    However, using GOTO's executes in the same amount of time, but uses half the program space. You have to be cautious of pages, though. The best way is with the basic goto command, but then you might get excess overhead with page checking.
    Portb.1 = 1
    goto skip1 'kills a minimum of 2 cycles
    skip1:
    goto skip2
    skip2:
    portb.1=0
    Russ,
    Using the same idea you can control all you pins at same time. Its not pretty or clever, but it works
    PortB = %00000001 ;pin 0 high 3us
    PortB = %00000001
    PortB = %00000001
    PortB = %00000010 ;pin 0 low, pin 1 high 3us
    PortB = %00000010
    PortB = %00000010
    PortB = %00000100 ;pin 1 low, pin 2 high 3us
    PortB = %00000100
    PortB = %00000100
    PortB = %00000000 ;all pins off
    Loop etc
    Tenaja is your name Don L?
    Sep 2007
    USA, CA
    Quote Originally Posted by mark_s View Post
    Russ,
    PortB = %00000001
    PortB = %00000001
    PortB = %00000010
    PortB = %00000010
    PortB = %00000100
    PortB = %00000100
    Loop etc
    Repetitive port settings on 16F (and lower) devices must also take into account the read/modify/write timing. If you place two consecutive settings in a program, you could end up with a random output setting because of the r/m/w delays.
    No.
    Don L. lives in Arizona, and sells stuff on ebay
    Edit: Oh and he will autograph his books too . . .
    My mistake he goes by "tinaja" not Tenaja. Don Lancaster was a big influence for me in the late 70's and early 80's.
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. Microcontroller with 2 way paging application problem
  3. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  5. Help Quick Need to make code smaller
    By Programmednew in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 04:46
