Ds18b20..
Results 1 to 6 of 6
Thread: Ds18b20..
    Mar 2008
    Am I right in assuming IF i dont use the constants then it would default to 0.0625°C resolution and take 750ms to take a reading?
    BUT IF I want to change the resolution I'd use the constants, but the code would be
    OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_9bit]
    OR OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_10bit] etc?
    and this would take 187.5ms?
    OK figured out $33 is skip rom command, and $4E is Write scratchpad
    but what's the 0,0 after it?
    ANd IF I was using more than 1 temp sensor then it would be something like
    OWOUT  DQ, 1, [$55,$28,$B1,$FE,$22,$00,$00,$00,$5D,$44, $3F ]
    ; or do I HAVE to use the DS18B20_10bit instead of $3F?
    Assuming the ROM address is $B1,$FE,$22,$00,$00,$00?
    I know that Match ROM is $55, Read ROM is $33, and Search Rom is $F0
    And I know the $44 at the end is telling it to start a temperature conversion
    Sorry for asking so many questions
    Mar 2008
    THINK I've sussed a bit more:
    IF I want to change the resolution from the default I can use something like
    OWOUT DQ, 1, [$CC, $4E, 0, 0, $5F] ' 11 bit resolution
    and to address individual 1wire devices I'd use something like
    OWOUT DQ, 1, [$55,$28,$B1,$FE,$22,$00,$00,$00,$5D,$44,$5F] THEN
    OWIN DQ, 4, [Stat]  ' Stat is constant + Check for still busy converting
     IF Stat = 0 THEN W1    ' Still busy?, then loop
     OWOUT DQ, 1,[$55,$28,$B1,$FE,$22,$00,$00,$00,$5D,$BE]
     OWIN DQ, 2, [Temp.LOWBYTE,Temp.HIGHBYTE]  'Read two bytes, + end communications
        GOSUB Convert_Temp
  1. Reading temperature using multi DS18B20
    By KVLV in forum Code Examples
    Last Post: - 3rd November 2017, 19:48
  2. Please help with code for DS18B20
    Last Post: - 28th April 2013, 21:12
  3. Help with DS18B20 program
    By presario1425 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2012, 00:50
  4. Multi DS18b20 Code help.
    By sccsltd in forum mel PIC BASIC Pro
    Last Post: - 18th December 2009, 06:13
  5. DS18B20 error reading
    By Gaetano in forum mel PIC BASIC Pro
    Last Post: - 29th August 2007, 16:21
