Compiler refuses to compile
Results 1 to 10 of 10
    Red face Compiler problems
    Hi Joe S,
    Yes, something is processing the assembler file but the file I have open in the editor window is the .pbp file, and I can't see anything in the options that might be telling the compiler to use the .asm file.
    Hi Skimask,
    The code above is not the Dev6.pbp code, but even in a one line program declaring a variable I get pretty much the same error messages. :{
    Here is the beginning of the Dev6 code
    TRISB = %11111111 ' Set PORTB to input
    TRISC = %11111111 ' Set PORTC to input
    TRISD = %11111111 ' Set PORTD to input
    CMCON = 7 ' Set PORTA to digital
    ADCON1 = 7 'Disable analog A\D
    TRISA.0 = 0 'Set PORTA.0 to output
    init: Pause 500 ' Wait for LCD to start up
    serout2 PORTA.0,84,[254]
    serout2 PORTA.0,84,[88]
    serout2 PORTA.0,84,["Hello"]
    PORTC.7 = 0
    PORTC.5 = 0
    sFocus VAR Byte 'Holds value to which focus will be set later
    panel VAR Byte 'panel number
    pLast VAR Byte 'last panel selected
    cFocus VAR Byte 'current focus
    stSq VAR Byte 'start square
    chars var byte[7] 'string chracters
    'charsW var word[7] 'string chracters
    stSize VAR Byte 'number of accumulated string chars
    arStart VAR Byte
    asciiCd VAR word
    myPort VaR word
    myString VAR WORD
    listPos VAR BYTE
    I think I shall have to strip it all off the computer and reload again.
    Mark
    Does this mean you are not using MPASM?
    PM_USED EQU 1
    If so, maybe you should set up MCS to use MPASM.???
    In the posts above, you have "INCLUDE 16F877A.INC"
    Do you actually have that in the program? MCS/PBP already take care of that for you.
    Doesn't sound like a bad idea...clean it all out... While your at it, spend the $25 and upgrade to PBP 2.50A.
    Here's the way I do a fresh reload. In my mind, I start from the PIC itself, and work my way backward, to the PBP source code itself...
    1) Load the programmer software/hardware/firmware. Test it out, make sure it recognizes and handles the programmer the way it needs to handle it.
    2) Load the latest version of MPLAB with any patches that need to be in there. Ensure that MPLAB can compile, and puts any result HEX files where you can find them.
    3) Load PBP and any patches that need to be applied. Try it out, compile a file, assemble it (whether you do it, or you set up PBP to let MPLAB do it, either way)
    4) Load MCS, connect it to PBP, connect it to MPASM.
    5) Try it all out.
    And don't load all of this into your "My Documents" folder. There seem to be the occassional 'long path' issues. It seems to work best for me if I put PBP in the root dir of C:, and MPLAB and MCS in their normal 'program files' folder.
    Talking Compiler problem solved
    Hi Guys,
    Thanks for all your advice, I have reloaded all the software elements and can now compile and load programs onto the PIC, but not sure why the compiler did not work in the first place.
    After reloading the software I still got the same error messages about the assembler file, so looked again at the compile and program options. Under assembler it said 'not defined', the find buttons were greyed out and the check box saying Use MPASM was unchecked, so I checked that and compiled a program without any problems. During compiliation some progress dialog boxes came up which I have never seen before so I am assuming that in previous instalations a different compiler was installed. Does that sound likely?
    After four evenings of frustration the joy that a little flashing LED can bring is surprising!
    Thanks to all who assist with these newsgroups, as a web programmer and not an electronics engineer I can only see half the picture and the information gleaned from these posts and the archives is invaluable.
    Cheers,
    Mark
    Do not know how far along you are in electronics and maybe you have been here
    http://www.parallax.com/tabid/535/Default.aspx
    There is a lot of good info and if you work through the experiments and adapt them to PBP I bet you will gain.
  1. compiler help!!!!
    By MINHLE in forum mel PIC BASIC Pro
    Last Post: - 20th April 2008, 19:52
  2. USB PBPL Compile errors
    By Rob in forum USB
    Last Post: - 7th April 2008, 09:18
  3. Cannot compile for 40MHz 4 x pll
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 21st October 2007, 18:50
  4. Replies: 2
    Last Post: - 9th February 2006, 23:03
  5. Newby- PBP wont compile for 18F (MPLAB)
    Last Post: - 18th December 2005, 00:30
