using a pot to control a time range
Results 1 to 5 of 5
    Try this. I've used something similar to it on a 12F675 and had no problems. You should be able to turn on the LED for up to 255 seconds (the maximum byte value).
    CMCON = 7 'comparators off
    trisio = %11111111 'ALL INPUTS - HIGH & LOW COMMANDS CONVERT TO OUTPUTS
    DEFINE OSCCAL_1K 1 'Set OSCCAL for 1K device
    POTVALUE VAR BYTE 'POTENTIOMETER VALUE VARIABLE
    LEDTIMER VAR BYTE 'LED TIMER VARIABLE
    START:
    LET LEDTIMER = 0 'RESET TIMER TO 0
    Low GPIO.4 'TURN OFF LED ON GPIO.4
    PAUSE 5000 'STAY OFF FOR AT LEAST 5 SECONDS
    ADCIN 1,POTVALUE 'READ VALUE OF POT
    IF POTVALUE = 0 THEN START 'STAY HERE OFF UNTIL POT IS TURNED
    LEDON:
    High GPIO.4 'TURN ON LED FOR 1 SECOND INCREMENTS
    PAUSE 1000
    LET LEDTIMER = (LEDTIMER + 1) 'COUNT SECONDS
    ADCIN POTVALUE 'READ POT VALUE
    IF POTVALUE > LEDTIMER THEN LEDON 'STAY HERE ON UNTIL LEDTIMER = POTVALUE
    GOTO START 'LEDTIMER = POTVALUE GOTO START & RESET
  1. 16F877 elapsed time control
    By BerkayT in forum mel PIC BASIC Pro
    Last Post: - 12th February 2009, 18:23
  2. servo control via pot ?
    By n0oxv in forum mel PIC BASIC Pro
    Last Post: - 1st March 2007, 08:11
  3. Control unlimited servos at the same time
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 19th September 2006, 15:14
  4. Button pressed time control
    By tanero in forum mel PIC BASIC Pro
    Last Post: - 15th August 2005, 16:17
  5. trying the pot command to control delay
    By reddogtj in forum mel PIC BASIC
    Last Post: - 20th May 2005, 13:50
