Hi all, and before I go any further I want to say thanks to everyone who has helped me before
The previous problem I had about trying to work a serial LCD, I've left that to one side for the moment, however for now... could anyone would be so kind as to look over my code and tell me what they see as obvious ( and not so obvious) mistakes.
The bits I'm not sure about is the config fuses/settings. I'm going to make a seperate mini board to plug a pickit 2 into with basically a 5v psu, 18 pin socket and the pic and any other bits needed like diode, resistor etc.
So ALL the programming will be done OFF the main board and all pins are being used as inputs or outputs only! (All digital)
Ra2
RA3
RA4
RA5 are ALL inputs (digital)
RA1
RA0 outputs to transistor switches
RB6
RB7 Outputs to LED's
so basically all pins are outputs apart from ra2,3,4 and 5 which are inputs.
the pic will be a 16F88
2 X DS18B20 dq from each going to 2 seperate pins ( porta.4 and porta.5 )
LCD 4 bit mode
RS is on portB0
E is PORTB1
Data pins PORTB.2 LCD D7
Data pins PORTB.3 LCD D6
Data pins PORTB.4 LCD D5
Data pins PORTB.5 LCD D4
Really not sure about ALSO the bits parked with ****** in the code i.e. ansel adcon trisa trisb and so on, (or the config fuses) it will be using an 8Mhz ceramic resonator as thats what I've got handy
The other thing I'm not sure about is the actual DS18B20's I dont know if I can have 2 each on a different port and address them as I have done, and IF I can,
How do I set this? DS18B20_12bit CON %01111111 ; 750ms, 0.0625°C resolution?
Sorry it wouldn't let me attach it as code (too big)
