TMR0 overflow problem
Results 1 to 11 of 11
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Runtimer:
    TMR0ON = 1
    TMR0IF = 0
    IF TMR0IF = 1 THEN HIGH PORTB.4
    GOTO Main
    Your polling technique has holes. When you enter Runtimer, you clear the flag and turn the timer on. If it has not overflowed, you go to main and spend a lot of time talking to your LCD ... then you turn the timer off. If the TMR0 overflows while in the LCD routine (odds are that this is where it will overflow), you clear the flag right before polling. Change to something like this:
    Runtimer:
    TMR0ON = 1
    IF TMR0IF = 1 THEN
    	HIGH PORTB.4
    	TMR0IF=0		' clear flag after you have trapped it
    GOTO Main
    Last edited by paul borgmeier; - 17th June 2008 at 08:49. Reason: EDIT: also add comments - makes your code easier to read
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Thank you for your help Paul. This looked like a logical solution, but now RB4 goes high on powerup, and stays there. I tried adding "LOW PORTB.4" after the ENDIF, and it goes low and never goes high! Strange behavior, I think.
    Now, I'm really confused. After reading the datasheet again, I tried to add the following lines:
    CONFIG1H = %00001000 'INT OSC Switchover & FSCM disabled, INT OSC enabled
    CONFIG2L = %00000001 'BOR, PWRTEN disabled
    CONFIG2H = 0 'WDT disabled
    CONFIG3H = 0 'MCLR disabled
    CONFIG4L = %10000000 'DEBUG, LVP, STVR disabled
    CONFIG5L = %00000011 'CODE PROTECT disabled
    CONFIG5H = %11000000 'EEPROM & BOOT BLOCK not code protected
    CONFIG6L = %00000011 'WRITE PROTECT off
    CONFIG6H = %11100000 'EEPROM & BOOT BLOCK not write protected
    CONFIG7L = %00000011 'TABLE READ not protected
    CINFIG7H = %01000000 'BOOT BLOCK TABLE READ not protected
    MPASM says "Syntax error". Why? Programs won't compile using PBP 2.50, it says use MPASM. Is this correct?
    Skimask-
    Yes, I read Melanie's fine post. That's why I put those lines in the program. She also said to use what's in the .INC file. There are only three items in my .INC file, none of which correspond exactly to the datasheet.
    Quote Originally Posted by jderson View Post
    Skimask-
    Might want to re-read that post again then...because you're not really supposed to add lines to your main program...you can, but there's a few things you have to do first.
    The items in the INC file are also listed in another file, the config options that is.
    And where might I find the "config options" file?
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  2. Can't ID interrupt source with this IntHandler??
  3. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 16:10
  4. Measuring change of frequency with PIC
    By Aussie in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 02:47
  5. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 02:17
