TMR0 overflow problem
Results 1 to 11 of 11
Threaded View
  1. #2
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Runtimer:
    TMR0ON = 1
    TMR0IF = 0
    IF TMR0IF = 1 THEN HIGH PORTB.4
    GOTO Main
    Your polling technique has holes. When you enter Runtimer, you clear the flag and turn the timer on. If it has not overflowed, you go to main and spend a lot of time talking to your LCD ... then you turn the timer off. If the TMR0 overflows while in the LCD routine (odds are that this is where it will overflow), you clear the flag right before polling. Change to something like this:
    Runtimer:
    TMR0ON = 1
    IF TMR0IF = 1 THEN
    	HIGH PORTB.4
    	TMR0IF=0		' clear flag after you have trapped it
    GOTO Main
    Last edited by paul borgmeier; - 17th June 2008 at 08:49. Reason: EDIT: also add comments - makes your code easier to read
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  2. Can't ID interrupt source with this IntHandler??
  3. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 16:10
  4. Measuring change of frequency with PIC
    By Aussie in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 02:47
  5. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 02:17
