PIC driven transistor - smoothed signal edge - why?
Results 1 to 11 of 11
    Wink
    Hi, Dave
    This scope ... has already shown its limits with Flotul :
    We were offered a wonderful sample of demodulated "HF" ( LoL ... better to say Mid Freq ) signal, some posts ago ...
    Now, this waveform is perfectly correct and true ... and shows bipolar switching limits with unipolar supplies ...
    I also have samples of that ( but taken on an ... analog scope !
    SWITZERLAND (french speaking)
    My scope is a "cheap" HANTEK DSO-220 USB modell
    I couldn't try Alain's suggestions up to now; don't have any Schottky diodes neither 1nF capacitors... will be bought and tested by tomorrow evening.
    My initial question was more about to understand the difference between both transistors since nothing else changes in the circuit.
    Quote Originally Posted by Acetronics
    so, might we say it is a " Flatul Hence " ???
    I wish this was true: I would bother you All again with a methane powered PIC project
    Roger
    Dec 2005
    Interesting. It looks like it was copied from the Protek 220 which was an ISA card DSO capable of 20 million samples per second. Of course, the sampling rate will be much slower using USB. The GUI is identical to Protek's with the exception of the colored knobs.
    Wink
    Let's be honest ... and use the tools for what they are intended to do ...
    Amateur ...
    This is exactly the same feature : junction capacities to discharge ... a strong cut off is obtained by polarizing the base to - 2 to 3 volts ...
    just look at old "logic" schemes !!!
    Ah, la vache !!! ...
    have a Good evening ...
    Amateur, amateur...
    In the early 1900's, the very best professionals & engineers built the Titanic
    Roger
  1. PIC conducting signal current when off
    By Viberer in forum Off Topic
    Last Post: - 28th May 2009, 18:27
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  4. Pic driven digital audio delay
    By skimask in forum Off Topic
    Last Post: - 19th April 2007, 21:42
  5. 8 port Signal Loss Detector, possible to use a pic?
    Last Post: - 20th March 2006, 16:59
