PIC driven transistor - smoothed signal edge - why?
Results 1 to 11 of 11
    Wink
    Hi, Flotul
    Never heard of transistor parasitic capacities ??? ...
    Search Keyword is " Totem pole " ...
    Also, try to use a // capacitor ( 1nF) on your 1K2 res ... or a BAT85 ( Schottky ) diode ... in the right way to "pull off" electrons from the trans. base !!!
    You might see a litte enhancement.
    so, might we say it is a " Flatul Hence " ??? ... LoL !!!
    Hi Roger,
    I don't think the Voltage waveform at the collector matters, since the LED operates from Current.
    According to the datasheet, the LED has 25pf capacitance. So when you turn off the transistor, that voltage can only dissipate thru the relatively small leakage currents.
    To allow the LED to discharge faster ... Placing a resistor across the LED would probably improve your waveforms, but it won't change the function and will only consume more current.
    A better indication of the Drive Current would be to measure the voltage across the 33 ohm resistor. Which should be very "square".
    What kind of o'scope is this?
    Sound card based?
    The second example show that OR your base resistor is a bit too low OR the source can't give enough current to your transistor base OR you o'scope can't draw the wave properly.
    Perhaps a resistor between the base and the emitter (around 2.2K) might help the transistor snap faster.
    Dec 2005
    It looks like a Protek 220 ISA bus scope card which has very high sampling rates. If I'm right, the scope is not a limiting factor.
    And 21 cycles at 38kHz is ~550uS which is a typical burst duration for several IR protocols.
    Wink
    Hi, Dave
    This scope ... has already shown its limits with Flotul :
    We were offered a wonderful sample of demodulated "HF" ( LoL ... better to say Mid Freq ) signal, some posts ago ...
    Now, this waveform is perfectly correct and true ... and shows bipolar switching limits with unipolar supplies ...
    I also have samples of that ( but taken on an ... analog scope !
    SWITZERLAND (french speaking)
    My scope is a "cheap" HANTEK DSO-220 USB modell
    I couldn't try Alain's suggestions up to now; don't have any Schottky diodes neither 1nF capacitors... will be bought and tested by tomorrow evening.
    My initial question was more about to understand the difference between both transistors since nothing else changes in the circuit.
    Quote Originally Posted by Acetronics
    I wish this was true: I would bother you All again with a methane powered PIC project
    Roger
    Dec 2005
    Interesting. It looks like it was copied from the Protek 220 which was an ISA card DSO capable of 20 million samples per second. Of course, the sampling rate will be much slower using USB. The GUI is identical to Protek's with the exception of the colored knobs.
    Wink
    Let's be honest ... and use the tools for what they are intended to do ...
    Amateur ...
    This is exactly the same feature : junction capacities to discharge ... a strong cut off is obtained by polarizing the base to - 2 to 3 volts ...
    just look at old "logic" schemes !!!
    Ah, la vache !!! ...
    have a Good evening ...
  1. PIC conducting signal current when off
    By Viberer in forum Off Topic
    Last Post: - 28th May 2009, 18:27
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  4. Pic driven digital audio delay
    By skimask in forum Off Topic
    Last Post: - 19th April 2007, 21:42
  5. 8 port Signal Loss Detector, possible to use a pic?
    Last Post: - 20th March 2006, 16:59
