Output settings for 16F88
Results 1 to 14 of 14
    Dec 2007
    Red face
    Thanks skimask!
    Yes I did miss your point; of curse the "squarewave" must look better to the 5804 if the duty is more like 50/50!
    New code:
    for a = 0 to 2000 ‘ ten turns
    ST = 1 ‘ start pulse
    for b=0 to 28:next b ‘ on time
    ST = 0 ‘ end pulse
    for b=0 to 28:next b ‘ off time
    next a ‘ loop
    The motor runs at the same speed as before, perhaps with a little less noise. If I try to go below 28 it loses torque and I do not help to use different on and off times. I have tried both ways, shorter on time and shorter off time.
    S**t, I really thought this was the solution!
    Sep 2007
    USA, CA
    You *might* get a little more speed out of it if you ramp up to speed (i.e. set an acceleration rate) rather than instantly hitting the full speed.
    But, as Skimask said, steppers are designed for low speed, and once you hit their top speed in the circuit, the motor will stall...which is a nice way to stay stop.
  1. Bit Banging input to output on PIC16F876A
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 20:50
  2. PIC 16F684 Configuration Settings
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 16:18
  3. Serious Serial Situation Setbacks...
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 15:44
