16f877a help
Results 1 to 13 of 13
Thread: 16f877a help
    Omaha, Nebraska USA
    Arrow
    Oreo, it's not clear to us what you are using for a compiler, and for programming, and what physical platform you have for your '877A.
    Is your platform just an 877A and a solderless breadboard, or do you have a kit or development board of some sort?
    If you're using PIC BASIC or PIC BASIC PRO and haven't already done so, you might consider getting something like the MELabs X-1 board. It's available assembled or as a kit. One nice thing about packages like this is that they often come with several simple routines already tested, working, and you can use them as starting points to learn to do more.
    The nice thing about starting with simple, known-good programs is that you can start tinkering with them. As soon as something doesn't work, you can stop and look at your code and learn from what didn't work because you know that the core from which you started did work.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Jun 2008
    I appreciate all of the positive comments or suggestions. But as skimask pointed out I started at the wrong forum and completely wasted his/your valuable time. I want to thank Bruce and Russmartin and sonicm , they seemed to want to help.
    I will try and find the correct forum and not waste your time any more. This will be my last post here.
    Quote Originally Posted by oreo View Post
    Didn't waste any of my time...
    Looks like you wasted your time...
    Might not have wasted any time had a book or two been read a bit beforehand...
    But that's just me...
    I could be wrong...again
    Or you could download the evaluation version from M E Labs and jump right in and get your feet wet and be a <b>valued contributor here . . .
  1. 16F877 vs. 16F877A
    By DavyJones in forum General
    Last Post: - 11th April 2009, 18:22
  2. help my bluetooth and PIC 16F877A?
    By slimpeng in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 06:52
  3. Read the newbee threads, 16F877A no go.
    By BobbyA in forum mel PIC BASIC Pro
    Last Post: - 31st December 2006, 03:09
  4. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 18:52
  5. 1st 16F877A program in PICBasic
    By Borisw37 in forum mel PIC BASIC Pro
    Last Post: - 19th January 2005, 04:46
