16f877a help
Results 1 to 13 of 13
Thread: 16f877a help
    Re-Read Post #2 instead of PM'ing me...
    You'll get a lot more help that way.
    Jun 2008
    Ok here is the simple code I am trying to run. It compiles but the output doesnt come on
    #include <pic.h>
    __config (PCMDIS & IESODIS & BORDIS & UNPROTECT & MCLRDIS & PWRTEN & WDTDIS & INTIO); //I don’t know what is supposed to go in this, which is the main problem.
    main(){
    PORTA = 0;
    //CMCON0 = 7; //would not compile with these two statements in
    //ANSEL = 0;
    TRISA4 = 0;
    TRISA5 = 0;
    while(1==1){
    RA4 = 1;
    Do I need the config statement or not?
    Thumbs down Is this C or PicBasicPro? Hello!!!
    Let's see...
    I don't think the bulk of the above code will compile using MeLabs PICBASIC PRO, like the writing at the top of the page specifies these forums are generally for.
    I could be wrong...
    Please tell me if I'm wrong...
    I don't like to be wrong...
    I don't mind being wrong...
    But I still don't like it...
    I guess you were fetching a stick from the oven...
    Jun 2008
    at least im not a jerk!!
    May 2008
    Quote Originally Posted by oreo View Post
    you can read picbasic manual and check your syntax is correct? one by one
    like
    -main() in picbasic don't have
    -TRISA4 should be TRISA.4
    try to read picbasic manaual you should start from there.
    Maybe...maybe not...
    But my eyes work fine. Have you checked the focus on your monitor lately? Maybe that's why you didn't see the numerous references to PicBasicPro. It could happen...
    And sonicm is 100% right. Every one of those commands/statements/lines is easily converted to something usable with the PicBasicPro compiler...assuming one has the correct reference material and/or knowledge.
    A wild guess on my part, but looking at your config statement, I'm guessing that you're
    using the Hi-Tech PIC C compiler?
    Hi-Tech has a web forum. I'm sure if you signup there someone will be happy to help you get
    going, but you definitely will want to review the 877A data sheet.
    You'll need to disable A/D to use some pins as digital I/O, and RA4 is an open-drain type
    output.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. 16F877 vs. 16F877A
    By DavyJones in forum General
    Last Post: - 11th April 2009, 19:22
  2. help my bluetooth and PIC 16F877A?
    By slimpeng in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 07:52
  3. Read the newbee threads, 16F877A no go.
    By BobbyA in forum mel PIC BASIC Pro
    Last Post: - 31st December 2006, 04:09
  4. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 19:52
  5. 1st 16F877A program in PICBasic
    By Borisw37 in forum mel PIC BASIC Pro
    Last Post: - 19th January 2005, 05:46
