LCD issue with EasyPIC5
Results 1 to 13 of 13
Threaded View
  1. #7
    May 2008
    Florida
    Skimask- they have R\W hardwired to GND on this board.
    Well, Acetronics gets the cookie today.
    Adding:
    INTCON = 0
    ANSEL = 0
    ANSELH = 0
    Gets what I wanted on the LCD. Can't fix the EasyPic5 example code(yet). First learn how to crawl, then with luck I might be able to stand up.
    So far I have been working with 3 different chips, 16F877A, 877, and 84 on two different boards. Should I continue that way or try to focus more on one combination until I get on my feet?
    After spending a few nights reading posts here I saw most common problem was getting the darn chip configured and the ports set properly. I figured using 3 different MCUs would give me more chances to learn setting things up or break them as case may be.
    I want to Thank all of the members who have responded to my posts, don't give up hope.
    I may learn how to read the datasheets. Right now half is in english and the rest is in some ancient dialect that totally escapes me.
  1. I can not figure out an LCD issue
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 11th March 2010, 14:54
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. Code Issue - select case or 'if' issue - not sure why
    Last Post: - 7th October 2007, 09:52
  5. LCD will not start
